DataAssist -> Search -> Refine results
Thread begun 12/19/2009 11:42 am by elizabeth130596 | Last modified 12/21/2009 12:31 pm by Eric Mittman | 3178 views | 3 replies |
elizabeth130596
Hi - I have a site where we will be searching on members' credentials.
We are searching First upon their Interests,
Second upon Age groups treated,
Third upon their geographic location.
I am hoping that this feature, using the Search asisstn wizard from within Data Assist, will help me achieve this.
However, the search seems to only work to filter one criterion, the first one.
If a keyword exists within the first field Interests, but the following two conditions are not true, it will still return the results as long as the first result is true.
Search terms are taken from a drop down list and if they are included in the field being searched, the result gets returned. There are manytext words within the field being searched, so it is OK to return a lot of results.
Each search term uses the drop down list, and if that term is contained within the field being searched we want the result.
However, we are getting results when one or two conditions are true, not all three. That's bad.
Say I want a doctor who treats depression in children in syracuse new york, I do not want to see the doctors in New York city, yet that is what I get.
In the data assist search screen I am using Filter on Keyword, included in field and the AND connector for the other two criteria.
How can I refine my searches so that all conditions are true, only returning those results, and giving an Empty results reply when the results are false?
AND, if that doesn't work, how can I apply a second search behavior on a results page?
thanks. URLS are:
SEARCH PAGE:
search_by_INTERESTS.php
RESULTS PAGE:
results_..._interests.php
elizabeth
Using the AND separators within the DataAssist Search server behavior should account for exactly this type of situation.
When I try the search like you mention in your post I see what looks like a single record returned. Perhaps you are working on this and results are varying based on some things you are trying.
The best way to troubleshoot why the search may not be returning records that it should is to print out the query that is used. This will give you a good idea about what is actually going on in the query and may hold the answer as to why you are getting these results. You can print out the query that is being executed by looking for the line that starts out like this:
$query_limit_
You will put in a new line just after this line and add a die statement with this full variable referenced in it. The full name of this variable will depend on the table you are searching but the line you should add will look something like this:
die($query_limit_WADA<table name>);
When you add this to the results page it will print the query to the screen. If you cannot determine why the query is returning the results or is setup like you see it post back with the query and some more details about the search criteria you have crafted in the DataAssist Search server behavior.
elizabeth130596
Hi Eric, Actually, the search behavior is returning too MANY results. (Plus, at this point we only have 2 dummy records) What is happening is that when a person searches for a doctor who treats, say Anxiety, in Adults... the Search Assist returns doctors who treat anxiety (good) in children (bad). But even that is enough to have a not-specific result set returns. Code block for DataSearch is below.
1st param = Interests
2nd param = ages served
we want BOTH to be true in order to be included, not just one.
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rsPractice1;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "SELECT * FROM Vmempublic";
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("INTERESTS");
$KeyArr2 = array("ages_served");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["INTERESTS"]))?$_POST["INTERESTS"]:"") ."","AND","Includes","%20AND%20","%20OR%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr2,"".((isset($_POST["ages_served"]))?$_POST["ages_served"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_search_matrix_v3_INT"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_search_matrix_v3_INT"]) && $_SESSION["WADbSearch1_search_matrix_v3_INT"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_search_matrix_v3_INT"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
It seems that you have both of these set with the AND correctly. It may be your includes part of the search, it looks like you are using keyword type searches with 'includes' for the content. That means that if any of the values you are looking for are even partially present in the record it will be returned.
If you are getting the values from some dynamic select lists on the page then you should use text searches with exact matches. This should eliminate any extra results that are occurring because they contain partial matches.
If you continue to have troubles with this please try using the die statement for the query so that the query that is being used can be seen and investigated to determine what is going on.
