pass data from cart to checkout
Thread begun 12/19/2009 8:14 am by stefano391544 | Last modified 12/23/2009 4:41 pm by stefano391544 | 2240 views | 4 replies |
stefano391544
Hi everybody
is possible to pass data from the form of cart to checkout.php.
For example i would like to pass the value of a radio button from the cart to the checkout.
Thanks for help ;-)
Office Guy-172461
Have a look here:
Creating a form that spans multiple pages
147/
stefano391544
Originally Said By: Office Guy-172461
  Have a look here:
147/
thanks for your reply :)
the problem is not the code to use. The form in the cart page don't go directly to a page but the action of the form reload the same page and then redirect to the checkout page and lose post data
Is there a solution?
Thank you :)
There is a way you can do this with the action set to the same page. One thing you can do is add in some set session value server behaviors to the top of the page. In here you give the session variables a name and you can set the values to the posted values from the form. This way you can use these values on the next page or any page after this in the site until these values are deleted or overwritten. You make use of the values by referencing the new session variables that are set, you should be able to see these in your bindings.
stefano391544
yesss .work great!!! Thank you!!! :) :)
