Link Transaction Process
Hello,
1. i create one to many relational database. I would like data assist to insert the master table and the automatically insert default data to detail table ? is it possible ?
2. is there a way to send the inserted primary key to the nextpage(After insert page) ? for example i insert a member database, and on step2.php the inserted memberID will be add to the query string ?
3. i'm looking for example on how to manage many-to-many relationship table i believe the feature is in "Manage Relational Table" server behavior. What should i need to setup in my page before i press "Manage Relational Table" server behavior, because i got error: "You must have a multi-select or fields within a repeated region to use this interface".
For the student course you give as example, please provide step by step tutorial
