E-cart Error on displayed page
Thread begun 12/18/2009 2:28 pm by movygirl244169 | Last modified 12/19/2009 8:11 am by movygirl244169 | 1694 views | 2 replies |
movygirl244169
I try to view the page after inserting the add to cart button for a static page and get the following error:
Warning: Unknown: open(C:\php\temp\sess_p0d2qtif5bg4cff0mp9511tp73, O_RDWR) failed: No such file or directory (2) in Unknown on line 0 Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (C:\php\temp) in Unknown on line 0
I really need some help here because I've fallen behind on this little project and I haven't used eCart yet so I'm not really sure what the heck I'm doing. FYI I'm not a programer (... not even close!)
The error is saying that the session temp file cannot be created or accessed.
your currant setting in the php.ini file for the session.save_path is C:\php\temp.
the error is saying that this location does not exist.
you will need to create a folder named "temp" in the c:\php\ directory.
movygirl244169
Problem Fixed
Thanks for your help. I was able to create the file and now it works.
