ie6 problems
Thread begun 12/18/2009 12:01 pm by denise234045 | Last modified 12/21/2009 1:49 pm by denise234045 | 3544 views | 5 replies |
denise234045
ie6 problems
2 separate issues I'm having with 1e6...
1) The top navigation disappears
2) I rearranged the products results page so that it displays in columns, rather rows. It works great expect in ie6, where instead of 3 columns, 4 rows the products display in 12 rows with lots of bad white space...
For clarity, I'm attaching an image that shows how it displays in other browser and how it displays in ie6.
Thank you!!
We will need to a link to the page to see the problem in the browser in order to trouble shoot the problem.
denise234045
Here you go!
Products_Results.php?Search=true&CategoryID=5
The menu is not displaying because you heave not defined an image in the menu_ie.css file.
In the menu_ie.css file, change the background-image: none; property of the
ul#cssmw_home li span a selector to:
background-image: url(../../Images/btn_topNav.png);
as for the columns not displaying correctly in IE6, I cant spot the problem in the CSS, it's possible you have some conflicting styles. Perhaps the following article may prove useful:
css-column-tricks/
I manged to get the columns working by editing the ie6.css file:
I changed:
.contentBox {
padding: 12px;
.contentBox {
padding: 12px;
float: left;
overflow:auto;
height:300px;
and:
.productResultsWrapper {height:1%;}
.productResultsWrapper {height:1%;float:none; overflow:visible;}
denise234045
Thank you very, very much!
