adding multiple products to car wiht check box
Thread begun 12/17/2009 9:40 pm by elyas218928 | Last modified 12/21/2009 5:06 pm by Jason Byrnes | 3214 views | 5 replies |
elyas218928
adding multiple products to cart wiht check box
i am having problem adding multiple products to cart with check box.
i followed the instructions on webassist recipe file and i am using data assist and ecart.
when i add one product it adds all the products to cart. i cant get only one product as its ticked to be added to cart.
i have tried so hard but i cant get it to work
this is my code.
<?php require_once('Connections/conn.php'); ?>
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_Recordset1 = 10;
$pageNum_Recordset1 = 0;
if (isset($_GET['pageNum_Recordset1'])) {
$pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
$startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
mysql_select_db($database_conn, $conn);
$query_Recordset1 = "SELECT * FROM comp";
setQueryBuilderSource($query_Recordset1,$WADbSearch1,false);
$query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
$Recordset1 = mysql_query($query_limit_Recordset1, $conn) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
if (isset($_GET['totalRows_Recordset1'])) {
$totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
} else {
$all_Recordset1 = mysql_query($query_Recordset1);
$totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
$totalPages_Recordset1 = ceil($totalRows_Recordset1/$maxRows_Recordset1)-1;
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: Recordset1;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "AND id=0";
if (isset($_POST["AddToCartButton_x"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromList("id","ATCCheck","AND","=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_wa"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_wa"]) && $_SESSION["WADbSearch1_wa"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_wa"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
// WA eCart Get Info From RS
if (isset($_POST["AddToCartButton_x"]) && isset($totalRows_Recordset1) && $totalRows_Recordset1 > 0) {
$Redirect_redirStr="";
do {
$eCart1_itemID = floatval("".$row_Recordset1['id'] ."");
$eCart1_itemName = "".$row_Recordset1['name'] ."";
$eCart1_itemDescription = "";
$eCart1_itemWeight = floatval("");
$eCart1_itemQuantity = floatval("1");
$eCart1_itemPrice = floatval("");
$eCart1->AddToCart(1, "", $eCart1_itemID, $eCart1_itemName, $eCart1_itemDescription, $eCart1_itemWeight, $eCart1_itemQuantity, $eCart1_itemPrice);
} while ($row_Recordset1 = mysql_fetch_assoc($Recordset1));
if ($Redirect_redirStr != "") {
$eCart1->redirStr = $Redirect_redirStr;
mysql_data_seek($Recordset1, 0);
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
<head>
<link href="WA_eCart/CSS/eC_Clean_Slate_Verdana.css" rel="stylesheet" type="text/css" />
<link href="WA_eCart/CSS/eC_Simple_Slate_Verdana.css" rel="stylesheet" type="text/css" />
</head>
<body>
<table width="100%" border="0">
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
<form method="post" id="add_to_cart">
<tr>
<td width="17%"><input type="image" name="AddToCartButton" id="AddToCartButton" src="WA_eCart/Images/Slate/Btn4_EN_addtocart.gif" /></td>
<td width="28%">&nbsp;</td>
<td width="5%">&nbsp;</td>
<td width="17%">&nbsp;</td>
<td width="33%">&nbsp;</td>
</tr>
<?php do { ?>
<tr>
<td><?php echo $row_Recordset1['name']; ?></td>
<td width="5%"><input name="ATCCheck" type="checkbox" id="ATCCheck" value="<?php echo $row_Recordset1['id']; ?>" /></td>
</tr>
<?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
<tr>
<td>&nbsp;</td>
</tr>
</table>
<br />
<br />
</form>
<tr>
<td>&nbsp;</td>
</tr>
</table>
</body>
</html>
mysql_free_result($Recordset1);
1) The checkbox name needs to end in "[]"
<td width="5%"><input name="ATCCheck[]" type="checkbox" id="ATCCheck" value="<?php echo $row_Recordset1['id']; ?>" /></td>
2) The default where clause should be 0 != 0 and the trigger should be the chkbox:
change:
$WADbSearch1_DefaultWhere = " 0 != 0";
if (isset($_POST["ATCCheck"])) {
elyas218928
still not working
hi jason
thanks for your replay but after i made the changes you asked i still have the same problem.
even if i don't tick a check box and click add to cart it adds all products on the list to cart.
here is my modified code.
//WA eCart Include
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
} else {
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "0 != 0";
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
do {
$eCart1_itemWeight = floatval("0");
$eCart1_itemPrice = floatval("0");
and my form is
<tr>
</tr>
<?php do { ?>
<tr>
</tr>
<tr>
<td>&nbsp;</td>
</tr>
</table>
<br />
<br />
</form>
if i move the Data assist code before the record set i get no result at all.
looking forward to a solution
cheers
The recordset code is before the DataAssist search code, the recordset must be created after the DataAssist search code creates the where clause.
elyas218928
problem not solved
hi jason
i moved the data Assist code before the recordset but now i get only one record displayed and my rpeat region is set to 10.
even when there is only one record displayed if i dont tick the check box and click add to cart it adds it to cart. this is my code now.
//WA eCart Include
//Searchpage: ;
//Form: ;
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
} else {
do {
<tr>
</tr>
<?php do { ?>
<tr>
</tr>
<tr>
<td>&nbsp;</td>
</tr>
</table>
<br />
<br />
</form>
The main problem is that you only have one recordset on the page.
you need to have two recordsets on the page, one to show all of the items and create the Repeat region. the second one to add the selected items to the cart. The first one will not be filtered at all, the second will be filtered by the DataAssist search server behavior.
