Basic questions
Thread begun 12/17/2009 4:28 pm by mata_ratones395222 | Last modified 12/18/2009 4:00 pm by Jason Byrnes | 4851 views | 8 replies |
mata_ratones395222
Basic questions
i just bought the CFS (Contact Form Solutions)
i looked all around for a simple way to show how to make the cfs work, but i couldnt find anything
let me show how i make it work, if i am wrong please let me know
1. download the zip file
2. extract it
3. duplicate the file, ( the copy is the one that i will modified)
4. put the copy in my root file
5. open the contactus.php file (i am using Dw)
6. i drop my template in the contactus.php
7. i changed the wa_globals.php (write the email destination)
8. i drop my template into the thankyou.php (im not sure how this will display later)
so, am i right??
once that i upload the entire site, it should work???
exactly what files from the Contact Form folder, can i delete without problems?
did i forget anything else?
thanks
mata_ratones395222
now, i want to put a second contact form into my website,
how i do that?
do i have to copy a second file with all the php files into my root file??
or can i make it work with the one i already have?
if this is posible, what i have to do?
Have you read the read_me.htm file included with the contact form solution pack? This explains the basic steps for installing the contact form solution pack.
All of the steps you outlined are pretty solid. Really the only files that can be deleted from the Contact Form Solution pack are the read_me.htm file and the contact_styled.php if you are not using it.
As for creating a new CFS form on your site, you will likely want to change the email address it points to, so create a copy of the WA_Globals file, name it WA_Globals2.php in the new contactus2.php file, change the line:
<?php require_once('WA_Globals/WA_Globals.php');?>
to point to the new globals file:
<?php require_once('WA_Globals/WA_Globals2.php');?>
mata_ratones395222
Yes I did it
Thanks for let me know how to add a second form,
I read all the tutorials,
that is why I manage to make it work
I put the entire site temporally in a free hosting to see if everything works as planed, but my contact is showing a red rectangle in the bottom of my form,
this is my code, could you tell me how can i fix that?
thanks
</td>
</tr>
<tr>
<td><font color="#FF0000" size="1" face="Verdana, Arial, Helvetica, sans-serif"><b>*</b></font> <font size="1" face="Verdana, Arial, Helvetica, sans-serif">Requerido</font></td>
<td colspan="2"><span style="width:100%"></span>
<input name="send" type="submit" class="inputButton" id="send" value="Enviar"/>
<input name="reset" type="reset" value="Borrar" />
<input name="print" type="button" id="print" onclick="window.print()" value="Imprimir" />
</td>
</tr>
<tr>
<td>&nbsp;</td>
<td width="421"><style>
.textfieldServerError {
display:block;
margin:0px;
color:#CC3333;
border: 1px solid #CC3333;
</style></td>
<td width="63">&nbsp;</td>
</tr>
</table>
<div style="width:100%"><br />
<br />
<br />
<br />
<span id="commentsServerError" class="textfieldServerError"><br />
</span>
<label for="Security_code" ><br />
</label>
<br />
<br />
<br />
<br />
<br />
</div>
</form>
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationTextarea.js" type="text/javascript"></script>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationTextarea.css" rel="stylesheet" type="text/css" />
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "email", {validateOn:["blur"]});
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
</script>
please post a link so I can see the problem to tell what the cause may be.
mata_ratones395222
thesignsplace.comuv.com/
The following code on your page is causing the red box:
</span>
</label>
as far as i can see, it is orphaned code that can be removed.
mata_ratones395222
Thankyou so much man
I think now, that i make a good decision buying one of your products
If the technical suport is always this fast
I will buy more products from you company
thanks
once that I upload the site to the domain, i will test the form, if it doesnt work, I will ask more questions
You're welcome, let s know if you need more assistance.
