Line Item 1 is Invalid...help!
Thread begun 12/17/2009 1:49 pm by bec341098 | Last modified 12/18/2009 12:10 pm by bec341098 | 9146 views | 6 replies |
bec341098
Hi Forums,
I have read ALL the threads pertaining to this, and nothing has helped. Authorize.net say it's not their issue, so I am hoping that someone can shed some light on this.
So, intermittently, checkout is throwing this error, and here is what I get (certain info blanked out, obviously):
Your transaction could not be completed.
(TESTMODE) Line item 1 is invalid.
Response Code: 3
Response Subcode: 1
Reponse Reason Code: 270
Full Request:
x_login=XXXXXXX&x_tran_key=XXXXXXXXX_version=3.1&x_invoice_num=991e61002b374db60e5698cac9f64aee&x_test_request=TRUE&x_method=CC&x_type=AUTH_CAPTURE&x_relay_response=FALSE&x_delim_data=TRUE&x_delim_char=::&x_customer_ip=76.1.191.114&x_amount=3000.00&x_description=1 Sterling & 18K Earrings (C4-HE255), 1 Mercy Pearl Necklace (E4-4205YTU)&x_line_item=C4-HE255<|>1<|>550<|>YES&x_line_item=E4-4205YTU<|>1<|>2450<|>YES&x_card_num=XXXXXXXXXXXXXXXX&x_exp_date=1010&x_card_code=263&x_email_customer=TRUE&x_tax_exempt=FALSE&x_first_name=Bec&x_last_name=XXXX&x_address=XXXXX&x_city=XXXXXXXX&x_state=FL&x_zip=33931&x_phone=XXXXXXXXXX&x_fax=&x_email=rew@rewilson.us&x_country=&x_ship_to_first_name=Bec&x_ship_to_last_name=XXXXX&x_ship_to_address=XXXXX&x_ship_to_city=XXXXX&x_ship_to_state=FL&x_ship_to_zip=33931&x_ship_to_country=&x_ship_to_phone=XXXXXXXXXX&x_ship_to_fax=&x_recurring_billing=NO
Help? Thanks.
Bec
It looks to me like you have removed some of the parameters that are sent to Authorize.net.
In the XML you send, the line item is sent to authorize.net as:
this looks like it correlates to:
id<|>quantity<|>price<|>taxable
the string they expect is:
id<|>name<|>description<|>quantity<|>price<|>taxable
you have removed the name and description elements from the local checkout server behavior.
bec341098
Hi Jason,
Thanks. I tried to fix that, and got the same error. Here is what my line items look like now:
x_line_item=A2-13377<|>Sanibel Island Story Bead<|>
Sterling Silver Sanibel Island Story Bead. Compatible with most major brand bead bracelets.
<|>1<|>45<|>YES&x_line_item=K3-1934SBSSBR<|>Sand Dollar Bracelet<|>
Sterling Silver Sand Dollar Bracelet - 7 3/4 inches
I also tried stripping the HTML from the description, but got the same thing:
x_line_item=A2-13377<|>Sanibel Island Story Bead<|>Sterling Silver Sanibel Island Story Bead. Compatible with most major brand bead bracelets.<|>1<|>45<|>YES&x_line_item=K3-1934SBSSBR<|>Sand Dollar Bracelet<|>Sterling Silver Sand Dollar Bracelet - 7 3/4 inches<|>1<|>115<|>YES&
Help??
The description being sent may be causing the error. In the authorize.net code, change the description to a static value:
$AuthNet_itemized[0][1] = "x_description";
$AuthNet_itemized[1][1] = "Jewelry Store Order";
None of the values passed to Authorize.net can contain any HTML so you will need to strip them from the description, also make sure there is no HTML in the other columns.
The line item 1 error means that invalid information is being sent in the order description. Here is the authorize.net API guide. page 20 - 21 talks about the line item requirements:
AIM_guide.pdf
The code for bulding up the line item will look like:
while ( !$eCart1->EOF() )      {
  $nextIndex = count($AuthNet_itemized[0]);
  $AuthNet_itemized[0][$nextIndex] = "ID";
  $AuthNet_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("ID")  ."";
  $AuthNet_itemized[0][$nextIndex] = "Name";
  $AuthNet_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Name")  ."";
  $AuthNet_itemized[0][$nextIndex] = "Description";
  $AuthNet_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Description")  ."";
  $AuthNet_itemized[0][$nextIndex] = "Quantity";
  $AuthNet_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Quantity")  ."";
  $AuthNet_itemized[0][$nextIndex] = "Price";
  $AuthNet_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Price")  ."";
  $AuthNet_itemized[0][$nextIndex] = "Taxable";
  $AuthNet_itemized[1][$nextIndex] = "YES";
    $eCart1->MoveNext();
    $cartIndex ++;
This code is basedf on a cart named eCart1, your will be slightly different. To pinpoint where the problem is, one at a time, hard code the values. for example, change:
$AuthNet_itemized[1][$nextIndex] = "item1";
then test again. If you still get the same error, change:
$AuthNet_itemized[1][$nextIndex] = "item name";
and test again. then change the description and so on till you find the culprit.
bec341098
Hi Jason,
I figured out that yes, it is special characters that is squirreling everything. But I couldn't find it, as it was a double-space! Crazyness. So yes, I am going to try to strip the code from the description and possibly the name, and see where that gets us.
So, I hope this helps someone else: If you use iRite, it WILL insert a special character if you double-space!
Thanks so much for your help, I hope I don't have to ask you how to strip them!
Bec
Excellent, glad to hear you found the culprit.
bec341098
Jason rules....
It worked! Thanks so much, and happy holidays!
Bec
