can't see images in cms admin
Thread begun 12/17/2009 8:50 am by gruant2000381341 | Last modified 12/28/2009 4:35 pm by Eric Mittman | 6219 views | 11 replies |
gruant2000381341
I wanted to add lightbox to images, since my js has a specific folder for images I am keeping them there. I pasted the link in source view in cms, but only get the red x where the image is suppose to be. When looking at the actual page, the image is fine and lightbox works....but can't see the image in cms admin area. Why is that? It should be able to read the path just like any other page, right?
<a href="images/babylg.jpg" rel="lightbox[people]"><img src="images/babysm.jpg" alt="Intarsia Plans baby" width="80" height="164" border="0" />
the images folder referenced is my lightbox image folder, just a folder in my root folder
The reason you see the red x may have to do with the relative path you are using. Have you tried using an absolute path that starts with a slash or is prefixed with your domain URL? Please give this a try to see if it helps you get past this issue.
gruant2000381341
somethng odd
well I tried adding a / and tried adding the whole http url, but nothing worked.
So I am still stuck with the image issue.
I also ran into an oddity while trying to fix the image issue. For some reason, my code that I am pasting in source view is getting re-arranged. The code below is what I pasted into source view initially.
<a href="images/babylg.jpg" rel="lightbox[people]"><img border="0" alt="Intarsia Plans baby" width="80" height="164" src="images/babysm.jpg" />
when I hit save, then go back in and look at it again in source view, it has been re-arranged like below
<a rel="lightbox[people]" href="images/babylg.jpg"><img border="0" alt="Intarsia Plans baby" width="80" height="164" src="images/babysm.jpg" />
I fixed it again and saved and it again rearranged the code.
Any idea why this is happening? This might also be contributing to my image viewing issue.
gruant2000381341
anyone? please
gruant2000381341
I really need some help with this
MickW
Hi Gruant,
I just thought I'd let you know that I've used Lightbox successfully.
As you say the CMS Editor alters the code but this doesn't affect the lightbox effect.
The difference I have is that the images are uploaded to a folder within the cms folder - this made sense in my setup as the images would be uploaded and used by the client.
HTH Mick
gruant2000381341
I already had other things in place to add images and other javascript in place before adding cms, that's why I have to do it this way. I may end up re-writing some of the js if I can't figure out why I can't see images in admin. Can't quite figure out what my roadblock is with admin being able to follow my path.
I really don't understand why cms is moving around my code, I don't like that at all. These lightbox instances aren't the only code I am pasting. Some of it is also commerce related, and I don't want it to all come undone because cms decides to change stuff.
gruant2000381341
I got my image issue sorted out, but i would still like to know why cms is moving code on me.
When it comes to the rearranged code that you are seeing is there any effect from doing this? If the attributes for the tag are specified in a different order does it cause your pages or code to not work? I'm not sure why the attributes order seems to be getting reversed but I'm more curious about the effect that this is having on your code.
Also, do you know which way it is being stored in the DB? This will give a clue about when and where the reformatting is occurring.
gruant2000381341
hmm, well I tried looking in the db to see how it is being stored. But i couldn't figure out how to see the info without screwing something up.
I can say that the lightbox still works, and when looking at the actual...then right clicking and viewing source code...the code is definately re-arranged. I have since added some of my paypal buttons ( which are for selling of digital goods ). I haven't had a chance to test the functionality of the redirect to download upon paymment, but the actual buttons are displaying like they are supposed to. Hopefully tonight I can get a sandbox set up to test this.
