Error when going to results page...
Thread begun 12/17/2009 7:59 am by WilliFixit | Last modified 1/18/2010 1:17 pm by nickj | 5528 views | 5 replies |
WilliFixit
Hello,
I have followed the instructions for the extension and installed the search on the home page of www.bozemanfigureskating.org on the left side panel. However, when I put something into the text box and click Submit, I get the following error, and no search results:
Fatal error: Cannot instantiate non-existent class: simplexmlelement in /homepages/13/d284714075/htdocs/bfsc/search_results.php on line 32
Please help! -- It is really a problem to be testing this on the live site!
WilliFixit
Found out that the function requires PHP5. By default my 1and1.com domain uses PHP4. So I changed the extension to PHP5 and that solved the problem.
nickj
Error Message
So this means that Search BOSS does not work with php 4.x?
Need to know because my server will be set to 4.x for some time to come!
Nick
Office Guy-172461
This is from the Search for BOSS page:
System Requirements
Windows
  • Windows Vista, Windows XP SP2, or Windows Server 2003
  • 128 MB RAM (256 MB recommended)
  • Dreamweaver CS4, Dreamweaver CS3
Macintosh
  • Mac PowerPC or Mac Intel
  • MacOS 10.4.x, MacOS 10.5.x
Hosting requirements
  • PHP 5+
  • Linux and Windows hosts supported
WilliFixit
Originally Said By: nickj
Nick
Nick,
My server (on 1and1.com) defaults to PHP4, but found that renaming it to PHP5 would default then to the newer version. Don't know if that helps you though.
nickj
PHP 5 did the trick
If I want to use the search functions I may need to move to a different server.
