new table properties glich
Thread begun 12/17/2009 7:11 am by gruant2000381341 | Last modified 12/17/2009 12:00 pm by Eric Mittman | 1838 views | 1 replies |
gruant2000381341
I am having another issue with tables. I posted a thread a while ago about right clicking on a table and having the fly out being underneath the parent. I have since re-downloaded the cms solution, and now when I go to edit my table properties the fly out is completely on top of the parent. So when I right click, then click table proerties...if I need to get to the bottom-most option, I have to make sure my cursor is completely outside of the menu...go down to the option I want..then go into the menu. Otherwise, if I leave my cursor inside the menu and try to go down to the option wanted, the very first sub menu item that my cursor hovers over opens up on top of the parent menu and won't close. Then I have to click outside of the menu altogether to get it to close, (which also closes the parent menu) then start over from scratch. very annoying !!
I am having this issue only in IE8, I have tried several computers and several browsers and ie8 seems to be the only one affected.
Just for a check, to make sure I didn't screw something up on my installtion. I also tried on your demo page and it did the exact same thing for me there also (using IE8)
I attached a screenshot
hmmmmm, just tried this using opera and I can't even get to table properties by right clicking.....gives me no options at all
I have opened a ticket for you on this issue, to update the ticket or check it's status login to the site and visit your support history.
