Using URSP for subscription Membership via PayPal
Thread begun 12/17/2009 6:09 am by John Langer | Last modified 4/15/2010 5:56 am by John Langer | 3849 views | 4 replies |
John LangerBeta Tester
I've set up a site that uses URSP to register to gain access to certain pages of the site. No problem there.
I know need to set up a subscription service via PayPal. I've already been assured that this can be done. I know that I can create the buttons etc for one, six and 12 month memberships. I also know that I have to create an IPN listener page and I know the principal of how that operates. PayPal sends the info, the IPN listener on my site sends the exact same data back and then PayPal sends a VERIFIED message.
My problem is how do I write such a page and then how do I set the URSP database fields to the correct subscription? I've spent two days now in reading and Googling but I'm none the wiser for my efforts. Has WA got any tutorials on how to do this? Failing that is there anybody out there who would be willing to hold my hand in this venture. Or failing that is there anybody who would be willing to accept a fee for doing it for me?
I really would be most grateful of some help. I do have access to the entire WA Library.
Crafting an IPN page can be a little tricky if you have not done one before. If you have eCart there is a function you can use that will check to ensure the post coming to your IPN page is valid, this function is applied automatically in combination with the get contents from form server behavior when PayPal IPN is specified as the source. If you do not wish to populate an eCart from the IPN post you can use this function by itself, it is called WA_isValidPayPal() and can be found in the WA_eCart_Definition_PHP.php file.
In order to associate the subscription purchase with a user you will need an identifier. If you use the custom variable when sending the user to PayPal you can get back whatever you put in this variable on your IPN page. You can use this as an identifier for the user, or the order. You could check this value and update your db based on it. For example if you store the user's email or id from the db in this field you can use it as the reference for your update server behavior so that you know what record to update.
Post back with any other questions that you have or if you run into any problems and we will be glad to help. Also, make sure that you are testing your IPN page along the way by using the PayPal IPN tester in the developer center.
Hi Eric, many thanks for the reply.
I'll have a look at all of that. You explained the whole thing very well. With the info I've gleaned from the net and what you've just said it's beginning (slowly) to make sense. It's getting late over here in the UK so I'll look at this with fresh eyes in the morning and report back.
Let us know if you have any other questions on this.
zanimul379168 just pm'd me but I cannot see a way to reply. Assuming this was the post you were asking about I'll update what happened.
I found a script on the net that served me well. Well documented as well and it works which is the main thing.
Here's the link Stellar Web Solutions PHP IPN System V2.1 (for PayPal)
It was still a learning curve for me but worth the trouble. I couldn't find a better solution anyway.
