encrypt password field
is the encryption on passwords done in mysql or within dataassist?
so when the user registers a username and password the password needs to be encryped to the database.
thanks
thanks
The encryption would occur in the DataAssist server behavior for the insert or update. When selecting the column to hold the password you would use the lightning bolt icon to select the user password field then use the format option to apply the sha1 encryption to the value. This will get you inserting a password that is encrypted into your db.
