Cannot input | into text
Thread begun 12/16/2009 2:43 pm by andy.schofield283961 | Last modified 12/16/2009 6:51 pm by Eric Mittman | 1716 views | 1 replies |
If I try and add a | character into iRite i get the following error:
Incorrect datetime value
Example: Inputting data
Item 1 | Item 2 | Item 3
Then I get this error when updating:
Incorrect datetime value: ' Item 2 ' for column 'ContentDate' at row 1
Can you help please.
This is a problem because the insert and update server behaviors that we have rely on using this same character as the separator for the values. When I have encountered this in the past I have been able to work around it by altering the code for the insert and update server behavior. I first change the "|" character that is listed in the value string, changing it to be like this works for me:
Then further down in the server behavior find the values code that looks like this:
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
Then update it to match the new characters you have like this:
$WA_fieldValues = explode("*|*", $WA_fieldValuesStr);
If you have any trouble with any of this post back with the page in question and I can't point you to the specific lines you will need to change.
