Display average of database entries?
Thread begun 12/15/2009 9:22 pm by ijk76319396 | Last modified 12/16/2009 12:54 pm by Jason Byrnes | 3352 views | 5 replies |
ijk76319396
I have users rate each page on a scale of 1 to 5. I would like for the average rating to be displayed on the page. I have already created a recordset which has the table filtered by the user's ID. How can I display the average rating?
The SQL AVG() function to can used to get the average from a column:
SELECT AVG(rating) AS averageRating FROM table
ijk76319396
Can you check that this query is correct, when I go to open it in the bindings panel I get the message MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'table
WHERE 0 = 1' at line 1
$query_rsAVGRATING = sprintf("SELECT AVG(rating) AS averageRating FROM table WHERE ID = %s", GetSQLValueString($colname_rsAVGRATING, "int"));
$rsAVGRATING = mysql_query($query_rsAVGRATING, $con2com) or die(mysql_error());
$row_rsAVGRATING = mysql_fetch_assoc($rsAVGRATING);
$totalRows_rsAVGRATING = mysql_num_rows($rsAVGRATING);
ijk76319396
Fixed it, I left the value as 'table' instead of inserting the name of my table.
ijk76319396
Another issue
Another issue came up with some of the averages being way to long in size, how can I limit the average to be displayed to only two decimals, for example instead of showing 2.24333333, have it cut off at 2.24?
use the MySQL FORMAT function:
FORMAT(number to format, number of decimal places)
for 2 decimal places:
SELECT FORMAT(AVG(rating), 2) AS averageRating FROM table
