Inserting Table
Thread begun 12/15/2009 2:37 pm by fcoloccia331860 | Last modified 12/16/2009 12:06 pm by Eric Mittman | 1612 views | 1 replies |
fcoloccia331860
Inserting Table
I currently use iRite 1.0.3 and I noticed that when I insert a table and put in some data, the cell's width moves and is not proportionned.
Example, if I insert a table of 4 rows and 2 columns, and I enter data in the first cell, it increases the width of that cell, and decreases the width of the cell to the right.
Is there a way to resize the cell to make the 2 columns the same width, or lock it?
In my testing the table width is set when you configure the properties for the table. There will be evenly spaced columns based on the width that you define. You can alter the individual widths for cells by right clicking in them and going to cell properties, then set the width here. When you explicitly define the width like this it should not grow or shrink depending on what is added to that cell.
