Multiple Add to Cart Check Box Issue
Thread begun 12/15/2009 4:37 am by vito374252 | Last modified 12/15/2009 12:45 pm by vito374252 | 1662 views | 2 replies |
vito374252
Hi
I have a problem with my checkboxes when trying to add multiple items to the cart. Basically, if you select a box other than the first one, it will automatically select the first one too.
Here's the url: counsellors_Results.php
I appreciate your help on this.
The problem is caused by your label tags.
html:
<td valign="bottom" bgcolor="#F3F3F3" class="ResultsTableCell"><br />
<label for="ATCCheck">
<input name="ATCCheck[]" id="ATCCheck" type="checkbox" class="checkbox" validate="required:true" value="66" onclick="setChecks(this)" />
<span class="WADAResultsTableCellname"> Add counsellor to booking</span></label></td>
you have a few issues in your label tag:
1) the for attribute of the label tag should referance the name, in your case, where the name end in"[]", the for attribute must also end in "[]";
html:
<label for="ATCCheck[]">
2) when using a label tag, there are two methods:
a) Wrap with label tag.
b) Attach using For attribute.
you should choose one or the other, not use both.
your checkbox code should be changed to:
html:
<td valign="bottom" bgcolor="#F3F3F3" class="ResultsTableCell"><br /><input name="ATCCheck[]" id="ATCCheck" type="checkbox" class="checkbox" validate="required:true" value="66" onclick="setChecks(this)" />
<label for="ATCCheck[]"><span class="WADAResultsTableCellname"> Add counsellor to booking</span></label></td>
vito374252
Brilliant! Thank you so much for that!
