power gallery
Thread begun 12/15/2009 4:27 am by info362308 | Last modified 12/15/2009 8:56 am by Justin Nemeth | 2906 views | 1 replies |
info362308
power gallery
I have just installed power gallery on my small business server running IIS and Apache web servers. The apache web server is on port 888 and the access path is:
powergallery or powergallery or powergallery
The power gallery is running under the apache web server. The install went perfectly and the database connection is working fine. Problem - the test gallery I have created a does not shoe any of the pictures, either as thumbnail or main images. When looking at the properties of the image placeholders, I notice that the image reference is 'http://localhost/powergallery/galleries/grid_fullsize/index.php?gallery=1&theme=light'. It is obviously not using the correct 'localhost:888..' path, missing out the correct port number (:888).
Where do I change the global / gallery path to include this :888 port number ?
Justin Nemeth
Please see this thread, it has the code you need to add.
showthread.php?t=7733
-justin
