problem with store cart details and summary
Thread begun 12/15/2009 12:31 am by QuiruNet | Last modified 3/17/2010 10:34 am by Jason Byrnes | 6370 views | 13 replies |
QuiruNet
The problem is that the user buy the products, its save the operation that the use Bought, but if the user want to buy again, without close the explorer or firefox, the second time, this next operation rewrite the firts one.
I don´t how to make work that, i want to save every operation the user do, doesn´t matter how many time he buy.
If the user close de explorer and open again its work...
Add the following code to the Checkout Success page, after the </html> tag:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
QuiruNet
codoe return
This post has been deleted.
QuiruNet
it doesn´t work
i puted de code in /html:
mysql_free_result($rsSeo);
mysql_free_result($rsNovedades);
mysql_free_result($rsUsuario);
session_start();
session_destroy();
--- in de two tables the wrotte the same OrderReferenceID, but the order sumari the do well the same the two actions, but with the samen OrderReferenceID. BUT the table orders details, the do the same thing they rewrite the order with the second action.
MAY BE a have te wriete someelse in the code you told me befere..some session?, for the OrderReferenceID i use the ecartd: <?php echo session_id(); ?>, that that writte a long OrderReferenceID, for example:831607a670e5605028633c5cf9eda349
In the order sumary is working fine, still put the same OrderReferenceID, but do not rewrite the information, but in te order detail still rewrite de order detail if the user buy for second time witout close the explorer.
THANKS
Are you getting to the checkout success page? it will only change the outcome if you are actually getting to the checkout success page.
QuiruNet
the final step
the thing is the same user, forget to buy something...and he is buying and make a second order, the second order kill the first order in the order details table, but in the sumary order tamble save de operation without killing de firts one. Do you know why?
This problem occurs if an order is placed with out a new session occurring.
The session destroy code I sent should cause a new session to start.
On what page did you add the session destroy code?
It should be on the page that the customer is brought to after completing the order, before they can start a new one.
QuiruNet
i did how you told me
i put the code the page the user is finish the checkout, but the code kill all sesions less de sessio ID for the ordersummary, that still the same...and the user try to buy again the second order he buys kill the first order details table. I don´t know why still make that...i copy and paste just like that :
session_start();
session_destroy();
I have to put something else?.....
Try adding this code at the bottom as well:
session_start
unset(
$_SESSION);
session_regenerate_id(TRUE);
session_start();
QuiruNet
Error
Parse error: syntax error, unexpected T_UNSET in C:\Inetpub\vhosts\actualitysantiago.com\httpdocs\v09\cart_confirmar_pedido.php on line 457
LINE 457 unset($_SESSION);
I WROTE LIKE THIS:
session_start();
session_destroy();
session_start()
unset($_SESSION);
session_start();
