Static map: default location shows, but not buttons
Thread begun 12/14/2009 3:45 pm by pd81749394651 | Last modified 12/14/2009 5:56 pm by Jimmy Wu | 3060 views | 4 replies |
pd81749394651
Hi:
I'm new to this. I've been trying to create a map with static addresses, but only the default address shows up. I've attached the page code and the .js files.
The url is schools.html
Thanks in advance for any help you can give.
You have not uploaded the google_javascript/images folder to the server.
The page you have attached only has the one address in it, no others.
Jimmy Wu
The locations are getting loaded up correctly, but the markers are not being loaded, since your images directory in the google_javascript directory is not uploaded to your server.
You are able to click on the second address if you know where it is and the info box will come up. This is the same as with the default address as well.
pd81749394651
Thank you!
I'm learning.
Jimmy Wu
Glad to be of help. If you run into any additional issues, feel free to open up a new thread.
