Long Folder Names?
Thread begun 12/14/2009 11:24 am by Art | Last modified 12/15/2009 10:31 am by Art | 2112 views | 2 replies |
Art
Long Folder Names?
2ColumnFixedHeaderandFixedFooter_Nautica_css
Above is the folder name that is created. Right off, I don't like these and I want the default it to be shorter. What would be the best strategy for avoiding these in the future?
If I just change the folder name and then change the reference in the css, if I go back into the extension, will it want to output is back into the long folder name?
Justin Nemeth
The file name is created using your preset name. If you have a long preset name, the folder name will be long as well. You can rename the folder using Dreamweaver and will change everywhere it is referenced in the code too. If you want Sculptor to output a shorter name, make sure to save a preset using a short name. The names are created this way so the folder can remain uniquely named plus give you an indication what preset was used.
-justin
Art
OK, Thanks
Thanks, that answers it.
