Incompatible warning recommendation
Thread began 12/14/2009 10:43 am by Art | Last modified 12/15/2009 11:26 am by Jason Byrnes | 1474 views | 3 replies |
Art
It would be nice if extensions would warn the user if they are incompatible with script language types such as ASP or Cold Fusion.
I use ASP and I'm starting to warm up to which extensions work with ASP. However, even though I am using ASP, the extensions will "work" in Dreamweaver. It will write PHP into an ASP page and even create the script folders and will do so without any warnings at all.
As a courtesy to those of us that have not yet moved to PHP, it would be nice to have a warning that would alert us to the fact that we shouldn't apply these extensions.
In the meantime, could someone post a link to a list of extensions that can only be used on a php server?
I know that each extension has a "System Requirements" (SR) page but this is a bit of a "workout" to have to go through each page to find the SR for each.
thank you for the suggestion, I will log a feature request.
The following products are PHP only:
All Solution Packs
Digital File Pro Version 2
CSS Form Builder
CSS Menu Writer
Search For BOSS
HTML Editor
nay New products or Product Upgrades that we release will also support only PHP.
Art
Thanks for providing that list.
I'm so torn between working on a site that uses a dying language and investing time in recreating an entirely new site in a language I'm not all that comfortable with.
I only wish I had invested my energy toward learning PHP not ASP.
My life would be a LOT easier now.
Well, thanks for the help.
You're welcome.
When I first started developing dynamic Web Pages, I was working in ASP as well. I was not using Dreamweaver though, I was coding ASP in TextPad.
I started drifting to PHP about 6 years ago. I have found the transition form ASP to PHP to be fairly easy. The PHP.net website is very easy to use for looking up functions and getting code examples, much easier than the MSDN website. And the PHP community is very active and willing to help.
