showing ok in solurition recipies but not showing in my own data!
Thread begun 12/14/2009 12:35 am by kakadong | Last modified 12/14/2009 9:42 pm by kakadong | 3270 views | 4 replies |
kakadong
By following the solution recipies, I make a good DWC ,
but when I change the datatable ,
it didn't showing the charts
the data table has only two columns,
one is ID (varchar)
the other is por (INT)
I don't know why ...
and if I change the database which is provided by solution recipies
it work again!
i have turn the por into (decimal) ...
no luck!
is there any suggestion?
kakadong
This is the code
ok ====> works good
No ====> only change the dataconnection and datatable and Xlable (ID) and Yvalue(por)
BANG! it not showing !
kakadong
Sorry ,
Forgot to upload files
What if you try browsing directly to the DynamicWebCharts/Data/DWC_data1.php file?
kakadong
ok! I know the problem!
it seems like something wrong with the database connection ...
I use the dBug function ,
but something wrong with it.
After deleting the code which is used for the dBug ...
Everything goes well
Thanks,
