Problem Modifying New Preset Layout
Thread begun 12/13/2009 4:34 am by jonathan395400 | Last modified 1/12/2010 11:35 am by Jimmy Wu | 4594 views | 7 replies |
jonathan395400
Hi All,
I have also postsed this probllem within 'placing div within a div' although my issue seems to go further and adds problems with the UI.
To see theh problem first hand I have created a screencast of the issue as I use CSS Scultor 3.
Please watch the screen cast here:
WebAssist.html
Any suggestions / ideas appreciated.
Until I can find a solution, CSS Scultor is of no use to mw whatsoever.
Regards.
Jonathan Parker
Jimmy Wu
I tested following your steps and was able to reproduce the issue. I was able to work around this by deleting the test1 div and then adding it again. The divs then work again as they should. Let me know if that works for you.
jonathan395400
Tried the suggested work around
and it worked, but only for that editing session. If I then saved th eupdated present and attempted to edit it a second time the same problem appears, only this time the only way to get it to work was to delete the div I had entered in the previous editing session and adding it again plus any editing that I want to do this time. By the way if I had added 3 divs in the first editing session then I have to delete all three in the second editing session to regain correct functionality. So basically the work around does not work or is impracticle.
I seems that you have to go back to the original template layout each time to get correct functionality. i.e.: Remove all previous editing then add it again plus any further editing. This is the only way to get it to work correctly, but as I hope that you can see, totally impractical.
Until some years ago I was also a software engineer working in assembly, C++ and Fortran. BAsed on that experience and appologizing in advance if I am way off trach here!!! Can I suggest what I can derive from what I have seen?
The first assumption I will make is that the fundemental editing functionality is working. I assume this as the first edit appears to work fine, it is only subsequent edits that experience the problem. By definition you must save your first edit before you can start a second editing session.
So the logical possabilities are:
A) The updated edit data is incorrect or currupt in some way during either its contruction or saving to fixed media.
B) The retrieval of the stored data is corrupting what was stored and the corrupted data is causing the editing functionality of the system to mis-behave.
C) The problem lies within the editing functionality of the system. 'Bubbeling events' and children not passing the correct event data on to parents to handle default handling procedures. Just a gut feeling, nothing in particular. Just reminds me of problem from my distant past!!
ANyway, hope you get it sorted soon.
Regards.
Jonathan
Jimmy Wu
Thanks for the input. We will take a look at this issue and hopefully be able to get a fix out for it soon.
jonathan395400
Any News?
Has there been any progress and the problem that I reported re: CSS Sculpture 3? As yet I'm still in the position of not being able to use it (even though you are still taking money from my account each month!)
Any updates appreciated.
Jonathan
Jimmy Wu
I apologize for the delay in getting a fix out for this. Due to the holiday season, the schedule was pushed back. Hopefully we will be able to get a fix out for this soon.
ian44375
Same issues
Hello, I too am having the same issues. I am on a Mac if that makes any difference. I'd love to find out if there's a patch in the works and when it will be released.
Jimmy Wu
We just came out with a fix for the issue. I have opened up a backend ticket to send you the fix.
