JavaScript error while loading ...
Thread begun 12/12/2009 9:26 am by Fritz Stickers | Last modified 12/16/2009 3:37 am by Fritz Stickers | 2718 views | 5 replies |
Fritz Stickers
When I open an asp page in Dreamweaver, I get an error like in attach. It depends on what page I open which error (3 kinds) appears. It's not on all pages, only a few. It's not with a specific (server)behaviour that's on the page. There are pages with Universal Email, pages with restrict access to, ... . I don't have an idea what the cause is, it was there sudden !
A few days ago I upgraded from WA_Universal Email 2 to 3 because "2" doesn't work under CS4 (see thread : WA-Universal Email server behaviour - ERROR). This worked without the JS-errors, so that's probably not the problem. The error disappears when clicking "OK". On some pages I have to click a second time "OK" because a second error appears.
When the errors are gone, DW works normally !
The file where the error points to : WATrigger.js is not in that folder. I searched my pc and found it in another folder : C:/Users/MyName/AppData/Roaming/Adobe/DWCS4/en_US/Configuration/Shared/Controls.Scripts
I tried to copy it and placed it in the map that the error mentioned, but no result.
I found a few threads on the forum with problems with the same errors, but no solutions !
Windows 7 Pro 64 bits
DreamWeaver CS4
UEmail 3.0.7
WA eCart 2.1.0
Fritz Stickers
... solved for a part
I unistalled WA_eCart 2.1.0, downloaded the newer version WAeCart220.mxp and installed it. But then I had the error "Dreamweaver CS4 doesn't work anymore". So, I unistalled eCart 2.2.0 again and reinstalled eCart 2.1.0 back.
I also copied the file "WATrigger.js" to the folder that te error mentioned. And yes ... errors are gone, so that's already solved !
But now I get another JS-error when I start up Dreamweaver : RSSUpdate.js ... (see attach). Could it be that it has to do with the installation of eCart 2.2.0 ? Because the option "WebAssist Preferences" isn't available in eCart 2.1.0. Also when go to "Edit" and click on the "WA Preferences" I get another JS-error, see attach.
I think that some settings from eCart 2.2.0 were not removed from my pc (register, ...) and that this causes the errors !?
But how do I get rid of them ?
eCart 2.x is not compatible with Dreamweaver CS4. You will need to upgrade to eCart 4 in order to use it in Dreamweaver CS4.
Fritz Stickers
Hi Jason,
How come that everything worked fine in the beginning I installed CS4 ?
Isn't it possible just to get rid of this error (RSSUpdate.js) on the startup of DW ?
Isn't that something new from eCart 2.2.0. which I can delete it in the register or something ? That's the only error that borrows me !
The upgrade costs me againg $ 139.99 !
you need to uninstall eCart 2, it cannot be used in DWCS4.
then go to Edit -> WebAssist Preferences. On the memento tab, select never from the drop down list.
Fritz Stickers
Thanks Jason and to the "Holiday Sale"
I upgraded to eCart452 and problems are gone !
