open_basedir restriction in effect
Thread begun 12/12/2009 5:09 am by bill193172 | Last modified 12/14/2009 11:06 am by Jimmy Wu | 1566 views | 2 replies |
bill193172
Just set up an upload file form on an otherwise blank php page, following the Getting Started Guide for DFP2.
(Only other change I made was to set folder permission to 777 for the uploads folder, which I tried after the following problem was observed - same results.)
Getting the following when I browse to the upload.php file:
Warning: Unknown: open_basedir restriction in effect. File(/home/xxx/public_html/upload.php) is not within the allowed path(s): (/usr/local/lp:/proc:/usr/lib/php:/usr/local/lib/php:/tmp) in Unknown on line 0
Warning: Unknown: failed to open stream: Operation not permitted in Unknown on line 0
Fatal error: Unknown: Failed opening required '/home/xxx/public_html/upload.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in Unknown on line 0
The server is a fairly generic cpanel/Linux server.
How to fix?
bill193172
Disregard - was testing with an ip address before the domain name was associated with the site; this seems to have been the issue.
Jimmy Wu
Thank you for getting back with the resolution of the issue. If you run into any additional issues, feel free to open a new thread.
