Update a hidden field/ reformat table
Thread begun 12/11/2009 4:33 am by afbergh391792 | Last modified 12/12/2009 7:26 am by afbergh391792 | 1817 views | 2 replies |
afbergh391792
Using SecurityAssist and DataAssist I've created registration, profile, update, etc. pages.
I've a database field "modified_date" which I would like updated automatically with the current date whenever a record is entered/modified. I've made it a hidden field on the forms. My question is where do I place the code to set the field to the current date so that when the form is submitted the "modified_date" field is updated?
A second question involves the results page generated by DataAssist. The results table is horizontal and extends beyond the boundaries of the page. It would be more helpful if the table could be made vertical with results extending down the page. It seems this should be simple to fix but I'm lost . . .
THanks.
set the value of the hidden form element using the date() function:
<input name="modifyDate" type="hidden" id="modifyDate" value="<?php echo date("Y-m-d"); ?>">
the results table is just that, a table, you can change it to be horizontal by placing a closing and opening table row tag between each closing and opening table data cell tag.
In other words for each:
</td><td>
combination, change it to:
</td></tr><tr><td>
afbergh391792
THanks
I knew this was basic stuff.
Thanks so much for your reply, Jason!
