javascript error eCart
Thread begun 12/10/2009 8:03 pm by mdsayeed_u394092 | Last modified 12/14/2009 12:51 pm by Jason Byrnes | 2947 views | 5 replies |
mdsayeed_u394092
I am getting javascript error while trying to add add to cart button with recordset, If I use record set without where condition, it is working fine, but when trying to with WHERE clause in recordset, it throws javascript error
Please matter is most urgent, if I dont get solutions, it will take two more days as today is Friday.
Please help,
Here it is code
SELECT Product.*, Category.Cat_name
FROM (Category LEFT JOIN Product ON Product.Product_cat=Category.categoryID)
WHERE Product_cat = 'colname'"
Please help me, webassists technical team
thanks
is colname a parameter in the Recordset?
If so it does not need to be surrounded in quotes, when configuring the parameter, set the data type to text.
also the perenthises around the join are not needed:
can be:
FROM Category LEFT JOIN Product ON Product.Product_cat=Category.categoryID
If all else fails, remove the where clause, insert the add to cart button, then add the where clause back in.
mdsayeed_u394092
eCart working when I use where clause with enter value but not with URL Parameter
Thanks for your reply, let me explain, what is exact happening, when I use ecart with recorded(where cluase with entered value), add-to-cart works fine, code is below
SELECT *
FROM Product
WHERE Product_cat = '1'
But, my client wants to add category dynamically as master page, and product as detail page, (so, that he can add category with web developer) for this I joined two tables say table_category and table_product, and written following code
SELECT *
FROM Product
Name is colname , default value 1 and run time value $_GET['id']
recordset works fine, but when I try to add add-to-cart button, extension throws error
If this error dont get solve, believe me I need to work for every page (Physical page)
Hope you understand, and solve this issue
If you want I will provide url (email to you, I dont want my client url in forum)
you should not have quotes around the parameter in the where clause:
should be:
mdsayeed_u394092
checkout Process problem with paypal pro
Thanks for you reply to javascript error on ecart, I tried where clause without quotes, but still there is javascript problem, then I removed where cluase, applied add-to-cart button, and again kep where clause in recordset, it is working fine, i dont know, is it good practice, will it create problem in future,
I get result, but now I get problem with check process, not able to either go paypal site,(as express checkout or transaction on site working)
details are
gateway: paypal pro- usa
shipping service step 1 of 1
I selected No thanks
Orders:
step 1 of 2
I selected NO thanks check box
email:
I select No thanks, I will handle the receipt myself check box
In design step 2 of 2
I have kept cart/ as my site url
I did not get any response from paypal website
Please check this issuek, as this process only creating problem, beta release is ahead for this site
When I click on expresscheck out page, it will redirect to /pp_checkout_failure.php
if you want I will send paypal account information I mean api information
Jussay
please see the "Debugging eCart Transaction Failed issues" Tutorial in the how to section of the eCart support page:
ecart/
