Form passes to thank you page but no e-mail sent
Thread begun 12/10/2009 2:08 pm by dfrith246697 | Last modified 12/15/2009 11:18 am by dfrith246697 | 4103 views | 6 replies |
dfrith246697
I am using the Universal E-mail Extension for a form (contactmgt.php) running on a Linux server. The form gives no error and successfully passes to the Thank You page but no e-mail result is ever received (sent?).
Is the email server setting correct? in many cases this can be left blank to use the default php setting in the php.ini.
On some SMTP servers, the From Display Name setting on the From tab needs to be left blank.
Sometimes the email may be trapped in a spam folder. Double check that the email is not being caught as spam.
What is the email address you added on the To tab? is the From email address being pulled from the form? Make sure when testing that you are entering a different email address, some SMTP server will not relay an email where the from and to addresses are the same .
If all else fails, contact the host to see if they can look at the SMTP server error logs to see why the email is not being relayed by the SMTP server.
dfrith246697
The apache logs for the server are returning an error:
"Undefined variable on WA_Global_Mail_2" in line 29 of contaMGT.PHP
I previously gave the wrong domain - this file is located at contactmgt.php
Sorry!
Dave...
please post a copy of your contaMGT.PHP page so I can look at the code.
dfrith246697
Copy of Code
The form seems to be working OK now but it is showing errors in the server log. (See following):
[Tue Dec 15 16:35:44 2009] [error] [client 198.65.168.24] PHP Notice: Undefined variable: WAGLOBAL_Contact_Email_Subject in /home/benttree/www/benttreepbg.com/WA_Universal_Email/WAUE_contact_1.php on line 10, referer: contactmgt.php
[Tue Dec 15 16:35:44 2009] [error] [client 198.65.168.24] PHP Notice: Undefined variable: WAGLOBAL_Contact_Email_BCC in /home/benttree/www/benttreepbg.com/WA_Universal_Email/WAUE_contact_1.php on line 27, referer: contactmgt.php
[Tue Dec 15 16:35:44 2009] [error] [client 198.65.168.24] PHP Notice: Undefined variable: WAGLOBAL_Contact_Email_CC in /home/benttree/www/benttreepbg.com/WA_Universal_Email/WAUE_contact_1.php on line 30, referer: contactmgt.php
It shows that the subject bcc cc were not setup correctly and it was looking for the WAGLOBAL_Contact_Email_* setup. After you changed that the script started to work for the other email addresses you had added. I am still seeing these errors even though it is working now:
[Tue Dec 15 16:41:04 2009] [error] [client 198.65.168.24] PHP Notice: Undefined offset: 0 in /home/benttree/www/benttreepbg.com/WA_Universal_Email/Mail_for_Linux_PHP.php on line 113, referer: contactmgt.php
[Tue Dec 15 16:41:04 2009] [error] [client 198.65.168.24] PHP Notice: Undefined offset: 0 in /home/benttree/www/benttreepbg.com/WA_Universal_Email/Mail_for_Linux_PHP.php on line 115, referer: contactmgt.php
[Tue Dec 15 16:41:04 2009] [error] [client 198.65.168.24] PHP Notice: Undefined offset: 0 in /home/benttree/www/benttreepbg.com/WA_Universal_Email/Mail_for_Linux_PHP.php on line 166, referer: contactmgt.php
The WA Globals file contains:
$WAGLOBAL_Captcha_Width = "200" ;
$WAGLOBAL_Captcha_Height = "40" ;
$WAGLOBAL_Captcha_Characters = "5" ;
$WAGLOBAL_Captcha_Font = "Fonts/MOM_T___.TTF" ;
$WAGLOBAL_Captcha_BG = "ffffff" ;
$WAGLOBAL_Captcha_Noise = "000000" ;
$WAGLOBAL_Captcha_Text = "000000" ;
$WAGLOBAL_Captcha_BG_transparent = "0" ;
$WAGLOBAL_Email_Server = "" ;
$WAGLOBAL_Contact_Email_Subject = "Bent Tree HOA Contact Form Response" ;
$WAGLOBAL_Email_To = "wordprocess@assocpropmgt.com" ;
$WAGLOBAL_Contact_Email_CC = "president@benttreepbg.com" ;
$WAGLOBAL_Contact_Email_CC = "secretary@benttreepbg.com" ;
$WAGLOBAL_Contact_Email_BCC = "dfrith@wycombeweb.com" ;
Hope this helps!!!
does the contactmgt.php page contain the following line to connect to the globals file?
<?php require_once('WA_Globals/WA_Globals.php');?>
is on the page before the universal email code?
dfrith246697
Contactmgt.php page code
The opening part of the page code is:
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
<?php require_once("WA_Universal_Email/Mail_for_Linux_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "";
$_SESSION['WAVT_contact_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {
//WA Universal Email object="Mail for Linux"
//Send Loop Once Per Entry
$RecipientEmail = "".($WAGLOBAL_Email_To) ."";include("WA_Universal_Email/WAUE_contact_1.php");
//Send Mail All Entries
if ("index.php"!="") {
header("Location: thankyou.php");
