Attachment not working
Thread begun 12/10/2009 9:13 am by GaryDCoxDFW | Last modified 12/16/2009 4:19 pm by Jason Byrnes | 5194 views | 9 replies |
GaryDCoxDFW
I have everything workin in universal email except the attachment, I followed the instructions, but what should be the trigger on the file upload the submit or what? her is the formula that was created ontheServer file Name binding I am using the same Directory of attachment_folder on the server
attachment_folder/<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
any suggestion to reslolve the issue?
can you confirm that the file is being uploaded properly?
For the File Attachment binding in Universal Email try using:
<?php echo(realpath("attachment_folder/".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"])); ?>
GaryDCoxDFW
Getting the file name only not the file
I am one step a head, but I am now just getting the file name like picture.jpg as an example, but not the file, what should I do now the script got me to this point now thanks.
Send a copy of your page and the WA_UniversalEmail folder so I can have a look at the code.
GaryDCoxDFW
Reply to your request
I had a java script erro come up so I uninstalled universal Email and Digital file pro deleted the config file upder roaming apps reinstalled all the extensions then tried it agian and the erroe cam back up I was also getting a script error when I deleted the attachment script and saved it an re opened u Email from the bindings tap I did not get the error (big suprise) I then started gettingthe Java script error so I screen captured it so you could see it also I will attach the u email directory as a seperate files. I had to get creatqative to send you the files under the Uemail directory so I converted them to a PDF I hope this is what you needed, let me know if it is not. Thanks for the assist.
If you compress the Universal Email directory into a zip archive you can send the original php files, I will also need a copy of the php page you applied Universal Email to.
GaryDCoxDFW
Here is you file
Instead of here is your sign Here is your files I love his jokes
try changing line 25 of the WAUE_emailform_1.php file:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".(realpath("attachment_folder/".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]))  ." ");
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".(realpath("../".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]))  ." ");
GaryDCoxDFW
Sorry still nothing
Just got the file name from the 1&1 Server again.
I have created a support ticket to look into the issue with you. To update your support ticket, please log into your support history:
supporthistory.php?
