menu appears as text
Thread begun 12/10/2009 5:01 am by jerry394338 | Last modified 12/10/2009 2:15 pm by Jason Byrnes | 3284 views | 5 replies |
jerry394338
Menue appears as text. The page is in a sub directory so all my links to graphics, js, etc. start with ../ When I look at the page in live view the menu looks great. When I view in browser I get only the text. I am also using a seperate js menu on the page, a date script that both are working fine. Tried moving the page to the root and removed the ../ from the paths and that did not work. same results. any ideas?
Please post a link to the page so I can see the problem and investigate the cause.
jerry394338
link
test.htm
The menu is in the center for
Aquatic Center,Fees & Passes, Rules
Thanks Jason
It appears properly in Fire Fox.
The reason it does not show in internet explorer is that your age is missing the doctype tag.
Without a doctype tag, IE renders the page in quirks mode. Quirks mode uses the IE 5.5 rendering engine which causes the CSS to break.
Add the following to line 1 of you page to tell IE how to render the page properly:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
jerry394338
Thanks Jasen,
Works great in IE now !
you're welcome.
