How to automatically fill in form fields/ (suggest) phrases from database
Thread began 12/09/2009 12:02 pm by Roxana | Last modified 12/09/2009 10:37 pm by CraigR | 1395 views | 3 replies |
Roxana
This is probably not an ecart question, maybe it is not even a Webassist question, but here it goes.
On the address form our customers have to enter their country. First I wanted to do that with a drop down menu, but there are just to many countries, and I don't want to exclude any countries, just because they are too little.
Now I would like the field to fill in the information as the customer types, for example the customer starts typing "b", and the first country that starts with "b" is filled in. Then the customer types in "e" and "Belgium" is filled in. Then the customer types "r", and "Bermuda" is suggested, and so forth.
I would store the country names in the database in order to be able to filter them by language.
I saw this done on the Canadian Yellow Pages, and it looks pretty good.
Could anyone help me with this?
CraigRBeta Tester
there is a spry widget to do this, but you will need to create an xml recordset as your datasource first, (i can help with this if you don't get any better suggestions)
SuggestSample.html
Roxana
Hi Craig,
Thank you for your help. I looked at the link (and some other Adobe pages about xml recordsets and the auto suggest widget), and it looks quite complicated, which doesn't mean I am not going to try to work it out.
But my boss also wants the site to work when java script is disabled. Am I right, that java script needs to be enabled for this widget to work?
CraigRBeta Tester
I'm sure there are a lot of people out there who know more than I do, but I cannot think of as solution which doesn't use javascript.
A (php only) non-javascript solution would surely involve reloading the page.
(Have you tried using the Canadian Yellow Pages site with javascript turned off ?)
