ecart Repeat region problem
Thread begun 12/09/2009 10:11 am by QuiruNet | Last modified 12/10/2009 11:37 am by Jason Byrnes | 2693 views | 5 replies |
QuiruNet
i am building a ecommerce with ecart, i did all steps with the toturial...but when i am trying to use the repeat region in dreamweaver with the "ecart add to card button" to show all my products... the ecart button doesnt work, don´t send the information to the cart.php page ...to show the item i pick..(i use the repeat region fron dreamwever ).
The same problem happen to me when i use the looper wizard (lopper type: horozontal), the cart.php doesn´t get the items i chose, you can see the page if you want:
seccion.php?categoriaID=3&marcaID=2&familiaID=21
You will see the problem.
It may be that your server is experiencing a bug with session variables. First, try modifying the seccion.php page.
Look for the following line of code:
// WA eCart Redirect
if ($<your cart name>->redirStr != "")     {
header("Location: ".$<your cart name>->redirStr);
where <your cart name> is the name of your cart object. and change it to:
session_commit();
QuiruNet
next error
i get the this error:
Warning: Cannot modify header information - headers already sent by (output started at C:\Inetpub\vhosts\actualitysantiago.com\httpdocs\v09\seccion.php:170) in C:\Inetpub\vhosts\actualitysantiago.com\httpdocs\v09\seccion.php on line 174
line 170 <?php
line 171 // WA eCart Redirect
line 172 if ($ActualitySantigo->redirStr != "") {
line 173 session_commit();
line 174 header("Location: ".$ActualitySantigo->redirStr);
line 175 }
line 176 ?>
That error occurs if there is out pout on the page before the header function is used. See the following page for more details on solving the problem:
148/
QuiruNet
thank
thanks its working.
Do you know a toturial to use to make the chekout witout a pay plataform?
On the eCart support page, see the "Using the eCart Checkout Wizard" tutorial in the Solution recipe section:
ecart/
