Creating a Search Form using Check boxes
Thread begun 12/09/2009 8:30 am by karen.marley367377 | Last modified 12/22/2009 9:58 am by Jason Byrnes | 6314 views | 10 replies |
karen.marley367377
Hi
I have a table with a list of types to select. On the Search form, I want the user to be able to tick a check box to select a type, rather than a drop down list. Can you give me any tips on how to do this?
you will probably want to use radio button instead of checkboxes.
Probably the simplest way to make this work will be to get it working with a select list fist. Once the search is working with a select list, make not of the select list name, then delete it and replace it with a radio group.
make sure the radio group has the same name and set the value form each radio button to be the value in the database.
karen.marley367377
using radio bx group
Thanks Jason,
That works fine. I now want the user to be able to make more than one selection. i.e. radio button 1, and radio button 2, and radio button 3
Can you help please?
Then change the radio buttons to checkboxes;
type="radio"
to
type="checkbox"
karen.marley367377
Form Using Multiple Check Boxes, Want initial page load to show All
I have created a search form on the results page, using a couple of drop down lists and multiple check boxes.
Whe the page loads, or one of the drop down boxes is selected the page shows no results.
In order for results to show, one or more of the check boxes needs to be selected.
How can I have the initial page load to show all records, or have one of the drop lists show values without having to tick one of the check boxes?
The code from the page is as follows:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAproperties;
//Searchpage: properties_Search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "";
if ((((isset($_GET["submit"]))?$_GET["submit"]:"") != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Assembly"]))?$_GET["Assembly"]:"") ."","AND","=",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["HealthDay"]))?$_GET["HealthDay"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparisonFromList("SaleORLease","status","AND","=",0);
$WADbSearch1->addComparisonFromEdit("RegionName","region","AND","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Industrial"]))?$_GET["Industrial"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Investment"]))?$_GET["Investment"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Land"]))?$_GET["Land"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Licenced"]))?$_GET["Licenced"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Mixed"]))?$_GET["Mixed"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Motor"]))?$_GET["Motor"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Office"]))?$_GET["Office"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Residential"]))?$_GET["Residential"]:"") ."","AND","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Retail"]))?$_GET["Retail"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("PropertyType","".((isset($_GET["Storage"]))?$_GET["Storage"]:"") ."","OR","Includes",0);
$WADbSearch1->addComparison("RegionName","".((isset($_GET["region"]))?$_GET["region"]:"") ."","AND","=",0);
$WADbSearch1->addComparison("SaleORLease","".((isset($_GET["status"]))?$_GET["status"]:"") ."","AND","=",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_properties_Results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_properties_Results"]) && $_SESSION["WADbSearch1_properties_Results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_properties_Results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
type="radio"
to
type="checkbox"
karen.marley367377
Check Boxes - When single ones selected works fine but not when multiple selected
Have resolved my last reply issue, but now have another one! X
Have created multiple check boxes to look at one field in the main table recordset.
When each selected singularly the check boxes show the correct results. The problem is when more than one check box is ticked. I am using the DATA Assist Search Server Behaviour and the code is posted below:
$KeyArr1 = array("PropertyType");
$WADbSearch1->addComparisonFromEdit("PropertyType","Assembly","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("PropertyType","HealthDay","AND","Includes",0);
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET["Industrial"]))?$_GET["Industrial"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->addComparisonFromList("PropertyType","Investment","AND","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Land","AND","=",0);
$WADbSearch1->addComparisonFromList("PropertyType","Licenced","OR","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Mixed","AND","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Motor","AND","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Office","AND","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Residential","AND","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Retail","AND","Includes",0);
$WADbSearch1->addComparisonFromList("PropertyType","Storage","AND","Includes",0);
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
Can you see where the problem lies ?
Many thanks
Please send the full php page in a zip archive so I can see the form code as well as the DataAssist search code.
karen.marley367377
Check Boxes for Multiple Select
Hi Jason,
I have attached a zip file for your perusal.
Many thanks and regards,
Sorry, I need a little clarification, you say it works when one is selected, but if more than one is selected it does not, can you explain what you mean by this? What is the result you are getting when more than one is selected versus the results you are expecting?
karen.marley367377
Check Box Selection
Apologies Jason, the check boxes now select expected records, expect....
The recordset is filter by a session variable - i.e. members id. When the page is loaded or the drop down lists in the search form are selected, it shows just the records entered by the particular member. when the check boxes are selected however, it shows all the members records ! X Help! X
$MMPARAMSLNID_WADATABLENAME = "1";
if (isset($_SESSION['SESSIONNAME'])) {
$MMPARAMSLNID_WADATABLENAME = (get_magic_quotes_gpc()) ? $_SESSION['SESSIONNAME] : addslashes($_SESSION['SESSIONNAME]);
