Image Upload
Thread begun 12/09/2009 6:51 am by dhagood355349 | Last modified 1/25/2010 11:55 am by Jason Byrnes | 7141 views | 14 replies |
dhagood355349
Image Upload
I bought HTMLEditor and I can not get Image Upload to go active. I have selected all the "upload" setting so they are all active. What am I missing?
You also have this issue posted in another open thread:
showthread.php?p=33592&posted=1#post33592
see my reply there.
dhagood355349
Thanks for the info. To bad this stuff does not work like it should once installed.
info271221
Image Upload Errors
I just upgraded from iRite to HTML editor and am having problems uploading images. Please see attachments for website.
This page: directory_Update1.php
You must first login in (login button on top right) user id: 226 and password JJ
Then go down to the HTML editor and try adding an image. It displays two different errors one when trying to browse server for an image and another one when trying to upload an image to the server. Thank You!
I'm logged into the directory_Update.php page on your site, and I do not see an html editor instance. It looks like you are using another editor from DMXZone.
info271221
you went to the wrong page
directory_Update.php is a working page (using DMZ zone).
We want to use webassist HTML Editor instead and I'm testing it online at this page: directory_Update1.php (I will remove the 1 once it is working and over-write the DMZ file)
directory_Update1.php gives the following error on load:
Unknown column 'fldsupplincome' in 'field list'
it seams you have a recordset that is referencing a column named "fldsupplincome" that does not exist in the DB.
info271221
sorry, now the page is working (except HTML editor)
Those are both permissions errors saying that it cannot create the directory "uploads_dl_photos" on the server. Create the folder named "uploads_dl_photos" manually and set permissions for it to 755
info271221
permissions set - folders created
The directory folder "uploads_dl_photos" is already created on the server; which the permissions set to 755 (read, write...).
Thanks for your help!
