Can I choose a language?
Thread begun 12/09/2009 2:13 am by info259249 | Last modified 12/09/2009 10:05 am by Jason Byrnes | 1216 views | 1 replies |
info259249
Hello.
I would like to know if it's possible to choose a language (ex. italian) for the maps and the driving directions.
Thanks.
You cannot choose a language in the Pro maps wizard, but you can edit it after to change the language to Italian.
After adding a map to the page, a script tag will be added to connect to the google API:
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=<your API key>">/*wagmp*/</script>
you can add an additional parameter to the query string to set the language:
hl=it
so the script tag will be changed to:
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=<your API key>&hl=it">/*wagmp*/</script>
