create other option in forum and second clients details
Thread begun 12/08/2009 3:24 pm by mr hankey | Last modified 12/23/2009 12:41 pm by Jason Byrnes | 5123 views | 16 replies |
mr hankey
hi,
i have currently in my insert to clients table a forum with all the details, however if i need it to be a joint client sale i.e. mr and mrs smith how would i go about this?
also have a form that has a tick box which if ticked it produces another question?
if you could help me out that would be greatly appreciated.
many thanks
mr hankey
also would i need to add duplicate into the mysql table of clients?
i.e. what i have in there but twice?
thanks
mr hankey
could anyone from WA support help me with this please?
many thanks
Basically, you are asking about creating a many to many relationship.
A client can relate to multiple users, and a usert ca relate to multiple clients.
To do this requires a linking table:
clients:
clientID - Primary Key
clientName - text
etc.
users:
userID - Primary Key
UserName - text
etc
ClientUsers:
ClientUsersID - Primary key
usersUserID - Foreign key relation to users.userID
clientsClientID - Foreign key relation to clients.clientID
the ClientUsers table above is used to create the many to many relationship of users to clients.
to have a check box that shows another form element, apply required client side validation to the checkbox on the onBlur event, then add the Show hide form element response from the client side validation, also on the on blur event.
mr hankey
thanks jason for all your help. i think i get you however not sure if on the same track here.
what i would require is:
user can be related to multiple clients.
but my main issue is, creating a table the can hold a joint client app i.e. husband and wife application etc.
would i need the same columns in mysql in the same table:
firstname
secondapplicantfirstname
lastname
secondapplicantlastname
etc
hope this helps explain better :)
also is the on blur effect in dreamweaver or a webassist ext?
many thanks
you could do it this way, but that causes lots of data duplication which is what databases are used to prevent.
plus, what happens if you run into a case where you want to relate to three people? you need to add more columns.
This is why you use the linking table.
With the linking table, you link as many clients as you like to as many users as you like
the onBlur event is an html event. it refers to removing focus from one form element and focusing another
Go to the Bindings panel and select your text box. Then click the plus button in the bindings panel and select WA Validation Toolkit -> Client Validations -> required / Not Blank. When you apply this, make sure to set the event in the bindings panel to the onBlur event.
next apply the show hide form element validation response, also to the onBlur event of the checkbox.
mr hankey
thanks jason, so in the way of creating the form, how would i achieve this having it a forum which has same details on one side of screen same on ther with dataassist?
many thanks
I'm sorry, I understand what you are asking. can you provide some more details on what you are trying to accomplish.
mr hankey
thanks jason,
so basically the insert record form needs to be for a joint insertion. i.e. a couple making the application.
so in the insert record page that dataassist creates i need it to be first name etc but one side of page for first applicant and other half for second applicant. also i would require a next button at bottom as the page could become very long with the form fields that i need. could you advise on this?
hope that is better.
thanks again mate for your help
First off, what you re trying to accomplish will not be done entirely by DataAssist, you will need to do some manual development on this.
I would not create the form with First applicant details on one side and Second applicant details on the other side. I would break it down.
create an application table, this holds data unique to the application.
Create another table for the applicant information, this table will hold the personal inforamation for each applicant. It will have a foreign key relation to the application table to relate the applicant to the application.
The first form will be the application form, they will fill in all of the information about the application except for personal details.
When this is submitted the DataAssist server behavior will insert the application data to the application table. In the DataAssist Insert record server behavior, there is a session variable section. This is used to store the ID of the inserted record into a session variable, select the application ID column and the name to store the session as, remember this name.
The insert record server behavior will redirect to the applicant insert page. On this page is a form to fill in the applicants personal details. When this is submitted, the insert record behavior will store the personal details in the applicants table. For the Foreign key column that relates to the application table, bind to the session variable that is created by the insert Record behavior on the application page. Either leave the redirect blank or on the redirect page, offer a button to go back to the applicant insert page to add another applicant to the application.
So the work flow will be:
Create the application -> Add Applicants personal information -> Add additional applicant personal details or finish.
