DD Error: The request has exceeded the allowable time limit Tag: CFLOOP
Thread begun 12/08/2009 12:05 pm by gareth268181 | Last modified 12/08/2009 4:35 pm by Jason Byrnes | 6051 views | 1 replies |
gareth268181
Hi, I have just purchased Web Assist, followed all instructions and get the following error at the following webpage:
www.amdramtheatre.com.test.cfm, here is the code:
<cfquery name="qGetGroupsandShowsandShows" datasource="amdram">
SELECT memberID, memberGroupName, showID, showName
FROM tblmembers, tblshow
WHERE memberTypeINT = 1
AND memberActive = 1
AND showActive = 1
</cfquery>
<cfsilent>
<cfif (qGetGroupsandShowsandShows.RecordCount GT 0) >
<cfset WA_DDArray = "<script>" & Chr(13)&Chr(10) &"var WAJA = new Array();" & Chr(13)&Chr(10)>
<cfset oldmainid = 0>
<cfset newmainid = qGetGroupsandShowsandShows.memberID>
<cfif (NOT IsNumeric(newmainid))>
<cfset newmainid = ToString(newmainid)>
</cfif>
<cfif (oldmainid EQ newmainid) >
<cfset oldmainid = "">
</cfif>
<cfset n=-1>
<cfloop query="qGetGroupsandShowsandShows">
<cfif (oldmainid NEQ newmainid)>
<cfset n=n+1>
<cfset WA_DDArray = WA_DDArray & "WAJA["&n&"] = new Array();" & Chr(13)&Chr(10) & "WAJA["&n&"][0] = '"&WA_DD_Replace(ToString(newmainid))&"';" & Chr(13)&Chr(10)>
<cfset m=1>
</cfif>
<cfset WA_DDArray = WA_DDArray & "WAJA["&n&"]["&m&"] = new Array();" & Chr(13)&Chr(10) & "WAJA["&n&"]["&m&"][0] = '" & WA_DD_Replace(ToString(qGetGroupsandShowsandShows.showID)) & "';" & Chr(13)&Chr(10) & "WAJA["&n&"]["&m&"][1] = '"&WA_DD_Replace(ToString(qGetGroupsandShowsandShows.showName))&"';" & Chr(13)&Chr(10)>
<cfset m=m+1>
<cfset oldmainid = newmainid>
<cfif (NOT IsNumeric(newmainid)) >
</cfif>
</cfloop>
<cfset WA_DDArray = WA_DDArray & "var qGetGroupsandShowsandShows_WAJA = WAJA;" & Chr(13)&Chr(10) & "WAJA = null;" & Chr(13)&Chr(10) & "</script>"& Chr(13)&Chr(10)>
</cfif>
<cffunction name="WA_DD_Replace">
<cfargument name="startStr" type="string" required="true">
<cfset startStr = Replace(startStr, "'", "|WA|")>
<cfset startStr = Replace(startStr, "\\", "\\\\")>
<cfreturn startStr>
</cffunction>
</cfsilent>
<cfoutput>#WA_DDArray#</cfoutput>
<head>
function WA_ClientSideReplace(theval,findvar,repvar) {
var retval = "";
while (theval.indexOf(findvar) >= 0) {
retval += theval.substring(0,theval.indexOf(findvar));
retval += repvar;
theval = theval.substring(theval.indexOf(findvar) + String(findvar).length);
retval += theval;
if (retval == "" && theval.indexOf(findvar) < 0) {
retval = theval;
return retval;
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function WA_UnloadList(thelist,leavevals,bottomnum) {
while (thelist.options.length > leavevals+bottomnum) {
if (thelist.options[leavevals]) {
thelist.options[leavevals] = null;
return leavevals;
function WA_FilterAndPopulateSubList(thearray,sourceselect,targetselect,leaveval,bottomleave,usesource,delimiter) {
if (bottomleave > 0) {
leaveArray = new Array(bottomleave);
if (targetselect.options.length >= bottomleave) {
for (var m=0; m<bottomleave; m++) {
leavetext = targetselect.options[(targetselect.options.length - bottomleave + m)].text;
leavevalue = targetselect.options[(targetselect.options.length - bottomleave + m)].value;
leaveArray[m] = new Array(leavevalue,leavetext);
else {
leavetext = "";
leavevalue = "";
startid = WA_UnloadList(targetselect,leaveval,0);
mainids = new Array();
if (usesource) maintext = new Array();
for (var j=0; j<sourceselect.options.length; j++) {
if (sourceselect.options[j].selected) {
mainids[mainids.length] = sourceselect.options[j].value;
if (usesource) maintext[maintext.length] = sourceselect.options[j].text + delimiter;
for (var i=0; i<thearray.length; i++) {
goodid = false;
for (var h=0; h<mainids.length; h++) {
if (thearray[i][0] == mainids[h]) {
goodid = true;
break;
if (goodid) {
theBox = targetselect;
theLength = parseInt(theBox.options.length);
theServices = thearray[i].length + startid;
var l=1;
for (var k=startid; k<theServices; k++) {
if (l == thearray[i].length) break;
theBox.options[k] = new Option();
theBox.options[k].value = thearray[i][l][0];
if (usesource) theBox.options[k].text = maintext[h] + WA_ClientSideReplace(thearray[i][l][1],"|WA|","'");
else theBox.options[k].text = WA_ClientSideReplace(thearray[i][l][1],"|WA|","'");
l++;
startid = k;
for (var n=0; n<leaveArray.length; n++) {
targetselect.options[startid+n] = new Option();
targetselect.options[startid+n].value = leaveArray[n][0];
targetselect.options[startid+n].text = leaveArray[n][1];
for (var l=0; l < targetselect.options.length; l++) {
targetselect.options[l].selected = false;
if (targetselect.options.length > 0) {
targetselect.options[0].selected = true;
</script>
</head>
<body>
<form action="memberhome.cfm" method="get" name="frm_bio">
<select name="allgroups" id="allgroups" onchange="WA_FilterAndPopulateSubList(qGetGroupsandShowsandShows_WAJA,MM_findObj('allgroups'),MM_findObj('allshows'),0,0,false,': ')">
<cfoutput query="qGetGroupsandShowsandShows">
<option value="#qGetGroupsandShowsandShows.memberID#">#qGetGroupsandShowsandShows.memberGroupName#</option>
</cfoutput>
</select>
<select name="allshows" id="allshows">
<option value="#qGetGroupsandShowsandShows.showID#">#qGetGroupsandShowsandShows.showName#</option>
</cfoutput>
</select>
</form>
</body>
</html>
The link provided goes to a server not found error.
from the error report, it sounds like the qGetGroupsandShowsandShows recordset is returning to many rows for the script to loop through before the timeout limit is encountered.
try adding this to line one of the page to increase the time limit:
<cfsetting requesttimeout="3600">
Set the time to be whatever you want in seconds.
