Can't Install
Thread begun 12/08/2009 9:21 am by snap320984 | Last modified 12/09/2009 10:17 am by Jimmy Wu | 5699 views | 12 replies |
snap320984
Can't Install
I can't even get this to install - so far it is hanging up on step 4 - Watermark. I have given the entire gallery folder the permissions of 777 as well as the connections folder, but nothing. If I skip watermarking and go to install images and point it to the images folder - same thing...just says error.
Justin Nemeth
Can you check if you PHP is running in safe mode? If so, try turning that off and installing again.
-justin
snap320984
Won't Install
How do you do that? I haven't had any other problems installing programs that use MySQL and PHP - all my control panel says is: PHP 5.2.2 how do I see if it is in safe mode?
Justin Nemeth
Make a php page and put <?php phpinfo(); ?> in it. View that page in a browser and you can check the safe mode setting.
-justin
snap320984
Can't Install
Yes, the PHP Safe mode was set to off
Justin Nemeth
What is the exact error message you are getting on each of the steps you mentioned?
snap320984
Can't Install
Under the Add Watermark Title - is just the big red word "ERROR" - If I try to skip the step (which I don't want to do) and go to install images and go to my images folder - I get the same big red "ERROR" under Import Images
Jimmy Wu
Could you take a screen shot of the page that errors after it errors and post it up here please?
snap320984
Can't Install
Error shot attached...you can see, all it say is ERROR
snap320984
Can't Install
Well...after back and forth...now nothing? My web page is sitting blank with an error while I was trying to get this up today...is someone looking into this or can offer more help?
