can you modify already create datassist form
Thread begun 12/08/2009 8:43 am by mr hankey | Last modified 12/08/2009 1:46 pm by mr hankey | 2404 views | 4 replies |
mr hankey
hi,
i have created insert pages etc using dataassist wizard, however i need to go back an amend. Can this be done or do you have to redo the wizard?
many thanks
You can edit the page directly. Just add/remove or change whatever you want to in the form, then double click on the insert server behavior to adjust how the database is updated.
mr hankey
thanks, so you cannot actually go back and amend via wizard?
i have changed how i want it to look however i have since then added more columns to database.
You cannot edit via the wizard. The wizard creates the pages and you would need to edit the pages separately or start over with the wizard.
mr hankey
thanks for your response.
I need to create a custom form using dataAssist. I need to be able to have a second applicant which only appears when the second applicant tick box is checked. can you help me with this please?
many thanks for all your support
