cart not working but works on local server
Thread begun 12/07/2009 7:18 am by watercolor346374 | Last modified 12/09/2009 11:08 am by Jason Byrnes | 5643 views | 11 replies |
watercolor346374
This is a big problem. I am testing the cart on
dendritic.php
When I test it I get to the detail page for a product, click add to cart and then I get this page:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@meganisaacs.isaacsgroup.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.14 (Unix) mod_ssl/2.2.14 OpenSSL/0.9.8l DAV/2 mod_auth_passthrough/2.1 FrontPage/5.0.2.2635 Server at meganisaacs.com Port 80
I have gotten this before and I had to do all of my detail pages over.
I have included files: cart, WAcart, and a detail page
here is the message in my error log:
[Mon Dec 07 08:06:53 2009] [error] [client 88.254.149.15] Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace., referer: skyyomer.php
The error log you posted I dont think is for tyhe problem you are encountering with eCart, it must be from another script, it is reporting the referer as skyyomer.php.
The Internal server error is a very generic error, We will need more infomation to be able to get an idea of the cause. You can try adding the following code to line of the cart.php page to turn error reporting on:
error_reporting
(E_ALL);
if your host allows, this will raise the error reporting level and hopefully return a more helpful error,.
watercolor346374
I put the code in near the top, does it matter where it goes? I go the same message on the page. Here is the log error:
10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace., referer: img.php
it needs to be at line 1.
the error log you are sending:
is not associated to this issue, it is from a different referer "referer: img.php "
watercolor346374
I put it at the top and get the same message: you can check it at:
detail_alexandria.php?prodid=201
When you click add to bag you get the error instead of the cart.
Thank you
You will need to contact the host to have error reporting turned on. it appears they do not allow error reporting levels to be changed through the ini_set command. without a more informative error, it is impossible to tell what the cause is.
watercolor346374
cart messages
Hi Jason,
I contacted bluehost and they updated my file permissions and that was the problem. Now I am getting messages after clicking adding to cart and then I go to the cart and this message appears:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/isaacsgr/public_html/meganisaacs/test2/cart.php:6) in /home/isaacsgr/public_html/meganisaacs/test2/WA_eCart/WA_eCart_Definition_PHP.php on line 479.
I looked at the line and not sure how to change it. then if I press the checkout button the next error appears:
Warning: Cannot modify header information - headers already sent by (output started at /home/isaacsgr/public_html/meganisaacs/test2/cart.php:6) in /home/isaacsgr/public_html/meganisaacs/test2/cart.php on line 67
I checked my connections folder and the file looks ok. I looked at line 67 on cart.php and that is the header line. It looked ok to me.
Thank you
according to the error, the problem is occuring on line 6 of the cart.php page:
The headers already sent error means there is output to the page beforer the header function is called, that output is at line 6.
line 1 - 6 0f your cart.php page are:
error_reporting
(E_ALL);
The error is caused by the blank space at the end of line 4 and the blank line at line 5.
change the code at lines 1 - 6 to:
error_reporting
(E_ALL);
watercolor346374
cart still not working
Hi Jason,
I changed it as you said, and now I am back to the same error page:
Apache/2.2.14 (Unix) mod_ssl/2.2.14 OpenSSL/0.9.8l DAV/2 mod_auth_passthrough/2.1 FrontPage/5.0.2.2635 Server at www.meganisaacs.com Port 80
When I remove all error statements from the top of the page I get the same error message.
So I am back where I started. When I called bluehost and he fixed the file permissions it worked. Do not know what is going on.
Thank you
The permissions must have reverted back to what they where originally before blue host changed them.
