Timetable
Thread begun 12/05/2009 10:50 am by jebrandon343719 | Last modified 12/13/2009 10:18 am by jebrandon343719 | 2639 views | 4 replies |
jebrandon343719
Timetable
Hi, I need to display a 'timetable' on my webpage. The site is for a yoga studio. My client needs a way of entering and changing class times, then I need to display the timetable on the site.
I tried using Power CMS and created a table - This works okay, however, it is not very robust. - I'd like to have more control over the layout of the public page.
Has anyone got any hints as to the best way to do this?
We do not have any tools or solutions that would accomplish this for you but if you can post back and include a little more info about how it is currently working and how you would like it to work we can check things out and give you some pointers if we have any.
jebrandon343719
Multi dimensional array??
Hi Eric Thats for your reply.
What i want to do is display a table - see attached.
I have PowerCMS, so I was hoping to add a page that allowed my client to enter the data, so it could be updated as new times or teachers changed.
I thought that I could create a form and store the data in a database. It is the structure of the database that I'm unsure of, plus how to retrieve the data to populate the Timetable.
I think you are probably doing this the best way that you can with PowerCMS. If you wanted to take this to the next level you would need to make use of a db and a tool like DataAssist to generate some pages to help you manipulate the data in your db. I'm not sure how you would like to store this info but you may want to have a table that will have records for days, then another table that will record info for the events. You could also store the day with the event info eliminating the need for two tables.
If you store the info in your db then you could craft some recordsets to display the info and style the display in whatever way you would like. The specific db structure that you use would depend on what details you would like to record. You would want to ensure that your table had columns for each of the pieces of info you would like to store.
jebrandon343719
Thanks, for your help
