powergallery.php file deletion, How?
Thread begun 12/05/2009 1:16 am by Alan Shaw | Last modified 12/08/2009 12:50 am by Alan Shaw | 2220 views | 2 replies |
Alan Shaw
I am trying to overwrite or delete the above file on my sever via DW, but it will not let me, when I try to overwrite it I get the following message:
PowerGallery100\Connections\powergallery.php - error occurred - An FTP error occurred - cannot put powergallery.php. Access denied. The file may not exist, or there could be a permission problem. Make sure you have proper authorization on the server and the server is properly configured.
File activity incomplete. 1 file(s) or folder(s) were not completed.
Files with errors: 1
I've tried setting the permissions to 777 but nothing works.
I cannot delete the 'connections' folder in order to do a clean install as it still contains the php file.
Any ideas?
Justin Nemeth
If you wanted to delete the file, you could make a php page on the server then run it to do so. Make a new file in the PowerGallery100 and put this code in it, then run the file in a browser.
unlink
('Connections/powergallery.php');
I don't recommend doing this unless you are sure of the exact format for the connections file that you are re-uploading since all of PowerGallery relies on having that database connection.
Depending how much you've customized, it also might be easier to just re-run the install wizard and use your new database info.
-justin
Alan Shaw
Thanks Justin, just trying to do a bit of 'house keeping' and tidy up any old and unused files/folders.
