isEmpty() incorrectly returns true on checkout success page
Thread begun 12/04/2009 9:29 am by dori165961 | Last modified 12/10/2009 1:37 pm by Jason Byrnes | 3770 views | 7 replies |
dori165961
I have a client whose eCart store has worked great for over a year. About a week or two ago their customers started getting an empty cart error message on the checkout success page after placing an order.
The error message the customer sees is "Session Timed Out... Your order information could not be found." It's a custom error message I wrote that is only displayed if the cart is empty (so the customer doesn't see a blank order form if their session expired). In other words:
if (!$eCart1->IsEmpty())
// display shopping cart info
} else {
// display empty cart message
When I comment these lines, the shopping cart items and total are displayed properly.
We're using PayPal local checkout and this problem happens with both credit card and PayPal payments. My client reports that the problem is intermittent but has been happening with increased frequency lately.
Does anyone have any ideas why eCart is incorrectly returning true in this situation? Any thoughts are GREATLY appreciated.
hard to say without seeing the code in context. Can you send a copy of the page that is not working correctly so I can examine the code.
dori165961
Thanks for taking a look. Here's are three files:
confirm.php is the page where the customer reviews their order before clicking "Place Order"
checkout_success.php is the success page when paying by credit card
pp_checkout_success.php is the success page when paying with PayPal
The server runs Apache with PHP Version 5.2.11
Your code for determining if the cart is empty is a little more complex than you led on:
// If the cart is empty, it means the SESSION has expired.
// Don't redirect the customer -  display a message instead
if((!$_SESSION['OrderType']) && ($eCart1->IsEmpty()) && ($eCart2_giftcards->IsEmpty())) {
$display_empty_message "cart1_empty";
if($_SESSION['OrderType'] != "giftcards") { ?>
if ($eCart1->IsEmpty())     {
} else { ?>
if ($eCart2_giftcards->IsEmpty())     {
$display_empty_message "cart2_giftcards_empty";
// END of if($_SESSION['OrderType'] != "giftcards") ?>
to trouble shoot, I would change that code slightly:
$display_empty_message "cart1_empty - eCart2_giftcards_empty - not Session OrderType";
} else { ?>
then I would change part to display your custom message slightly to help track down the problem:
<?php if($display_empty_message) { ?>
Empty message: <?php echo($display_empty_message); ?>
Order Type: <?php echo($_SESSION['OrderType']); ?>
this will help to determine where to look for the problem by telling us which if statement is failing.
Then you need to twiddle the logic down, once you know which if statement is failing, you c an look into why.
Since you report this is happening intermittently, it may be a problem on the server. cart contents are stored in session variables, the server could have a problem in the session garbage collection where it is emptying the session temp files to soon, you would need to check with the host on that one.
dori165961
If you look in the body of the page where the cart contents are displayed, the code there is standard WA eCart code and not dependent on those if/then statements you pointed out. Disregarding the custom "Session Timed Out" message, the cart contents are simply blank on some occasions. The logic there uses isEmpty(). When I comment out the isEmpty statement, the cart contents will appear as they should.
I think you might be onto something with the session garbage collection, but I doubt the host (BlueHost) would admit to having a problem. My client just informed me that they remember BlueHost doing a server upgrade or maintenance of some sort November 25th, and that's when the problems started happening.
maybe try adding this code just before the cart if statement:
$eCart1
->GetContent();
$eCart2_giftcards
->GetContent();
to force it to look for the cart information again.
dori165961
The solution you suggested about GetContent seems to be working, unless there was something server-side going on that was fixed. The BlueHost server my client is on has been down 4 or 5 times this week. Either way, we're happy things are running smoothly again. Thanks so much for your help.
Excellent, glad to hear it is working.
