Problem with admin pages
Thread begun 12/04/2009 6:34 am by berndrendic374326 | Last modified 12/04/2009 9:28 am by berndrendic374326 | 1646 views | 2 replies |
berndrendic374326
I tried making admin pages with data assist several times but it never works ....
now i am getting this msg what does that mean... by the way i am using data assist with user reg pack....
Warning: require_once(Connections/localhost.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\Security_Assist\Admin\users_Results.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'Connections/localhost.php' (include_path='.;C:\php5\pear') in C:\wamp\www\Security_Assist\Admin\users_Results.php on line 1
thanks
Bernd
neilo
This indicates that the path to your connections folder is wrong in your results.php page. (It is probable wrong in your search, update, delete etc. pages too!)
Have a look at the first few lines of those pages.
The line will be something like:
<?php require_once('Connections/localhost.php'); ?>
If your pages are in your 'Security_Assist/Admin/' folder, and your 'Connections' folder is in the site root,
then that line should be:
<?php require_once('../../Connections/localhost.php'); ?>
berndrendic374326
thanks you are corect , in user reg pack those pages are in admin folder...
so when i recreated them again with data assist they were by default put in page folder ...
and i have moved it to admin thinking its where they should be ....
thanks i will try to play with this and see if it works
