Dropdown menu not fully populated
Thread begun 12/04/2009 4:57 am by georgina_barrett_187762 | Last modified 12/04/2009 4:45 pm by Eric Mittman | 1582 views | 1 replies |
I have a search page (created by the wizard) and one of the fields is a drop down that is dynamically populated. The problem is that the dropdown is only showing 999 records - not all of them. I have the same problem on an insert page (created by the wizard).
On this page did you manually apply the recordset and set the values of the select list to be dynamic? I tried to reproduce this in a test and was able to get thousands of records listed within the select list. Is there any limits on the query that is pulling the results?
