While executing OnLoad in WA_AppBuilder.htm the following JavaScript Errors Occurred
Thread begun 12/03/2009 2:17 pm by rabbaszadeh2007388864 | Last modified 12/04/2009 1:42 pm by Eric Mittman | 1861 views | 2 replies |
Hi
I got the following error as DataAssist is loading:
Anyone has seen this error, DataAssist was working, then stopped working after installing sculptor.
While executing OnLoad in WA_AppBuilder.htm the following JavaScript Errors Occurred:
In file "WA_AppBuilder" :
IntializeUI is not defined
Any suggestions will be appreciated.
david.barrack304604
I had this as well. I uninstalled DA completely, but then there is also a cache file that must be deleted. If you google using the error you receive you should see the files listed (Mac or PC).
You should try deleting your cache file and if that does not work you can rename the configuration folder. Here is a link to the steps to take for both of these techniques. Please give this a try and let us know if the problem persists afterwards.
146/
