ecart not linking to checkout
Thread begun 12/03/2009 12:12 pm by dengosha389983 | Last modified 12/07/2009 12:08 pm by Jason Byrnes | 2644 views | 5 replies |
dengosha389983
ecart doesn't allow me to add more than one item per page to the Display Manager. It also doesn't seem to want to find the link to checkout. All my store files are in a folder--does ecart need to be in the same folder? and if so how do I install it in the folder. Checkout shows as a blank page. If I put more than one item in the cart the cart empties.
Link to checkout page does not work:
There may be a php error occurring, add the following code at line of the cart display page:
error_reporting
(E_ALL);
ini_set('display_erros','on');
This should display the error if there is one occurring.
also add that code toi the checkout page so we can see why it is displaying as blank.
can you send a link to your site so I can look into the cart emptying when adding more than one item.
dengosha389983
I think that it is the server
I tested some of the pages on my own website dennisshapiro.com which is hosted by a different server and the Display Manager works perfectly. I cannot check the checkout as the domain is different. All the pages affected are: index.php. This is the beginning of the storefront I am developing for the Veterans Museum of Art. Thanks for the reply. I really appreciate it. There is another question I have. We intend on shipping everything USPS Priority Mail, their envelope which will contain a padded envelope to protect our books and prints. I keep getting a charge of $9.60 when USPS charges $4.80 when the label is processed over the internet. I have tried setting weight to zero but it is still doing this.
I think the server has a problem with session management.
to test, I am including a PHP file. Upload that to the server, then browse to it and follow the directions for testing session management.
if the session management test fails, you will need to talk to the host to have them fix the problem.
dengosha389983
Ran the sessions check
Jason
I ran the test you sent me and this is what I got: Session Test = NULL
(When the page is first loaded, the session variable test will = NULL, when you click the first link, the session variable test will be set to test. Clicking the second link will only reload the page, the session variable test should still equal test, if it equals NULL, your server has a problem with session management.
Session ID = c922e9b049627c23187200e96573360d
(NOTE: if sessions are working correctly, the session ID should not change.)
NULL shows up both times after clicking on the first or the second session test link. Test shows up first on the first link. But 2nd link only shows NULL.
I think we are going to change servers this week.
Thank you so much for the help.
Good luck with the new host, hopefully they will not have the same problem. The currant host will probably be able to resolve the session issue quite quickly if you bring it to their attention.
