Save my site layout as siteassist template
Thread begun 12/03/2009 12:06 pm by mr hankey | Last modified 12/09/2009 8:26 pm by Eric Mittman | 5017 views | 9 replies |
mr hankey
I have beeen trying to add dataassist wizard to my page that i have create. However the only template i can choose is siteassistpro. I have saved my page as dreamweaver template but cannot use this to add datassist to it.
Can anyone help with using my existing pages to save as template to use datassist with?
when i use dataassist and leave blank i get a blank page with the forms on it which i dont want.
many thanks
mr hankey
managed to save as template, not sure how. Think by fluke. However when i upload the template files and files created by dataassist it is saying page cannot be displayed in my browser?
Can anyone help me get these live?
thanks
mr hankey
ok changed version of php on my server from 5 to 4 which has helped slightly but not alot as i now get this message:
Warning: main(../WA_DataAssist/WA_AppBuilder_PHP.php) [function.main]: failed to open stream: No such file or directory in /home/sites/mysite.com/public_html/spectra/leads_Insert.php on line 2
Fatal error: main() [function.require]: Failed opening required '../WA_DataAssist/WA_AppBuilder_PHP.php' (include_path='.:/usr/share/pear') in /home/sites/mysite.com/public_html/spectra/leads_Insert.php on line 2
mr hankey
could anyone please helpme with these errors with my site being posted live?
Many thanks
mr hankey
I think i have resolved this issue.Will need to test but i think it was because the site was setup to documents rather than save at site root. Checked it out on Dreamweaver forums so hopefully this will resolve.
Whenever you get an error like this in php it is usually because either the file was not uploaded to the correct location or the way the file is being referenced in the include is not correct. If you know for sure that the files are uploaded correctly then you may need to adjust the include file path to ensure it points to the files properly.
mr hankey
hi eric, thanks for your help. As soon as i create a template in dreamweaver add a webassist menu to it and upload it does not display only shows the header.
Can you help as i would like to be able to use the extensions and upload live..
Do you have a page derived from this template that I can look over as an example? Either a link to the live page or the page itself posted in a zip archive would be helpful.
mr hankey
thanks Ericfor getting back tome,after speaking with tech support at my hosting company it was the virtual command in the first 3 lines that were causing the issue.
Resolved now. Thanks
Glad to hear that. I think you can control if this function is used in DW in your site setup, if you have it set to links document relative you should not get the virtual includes but the standard require once includes. Let us know if you have any further trouble with this.
