Fatal error: Call to undefined function curl_init() in C:\xampp\htd...............
Thread begun 12/03/2009 11:32 am by xberniex250371773 | Last modified 6/04/2012 12:57 am by manikandan.mjs439671 | 17343 views | 3 replies |
xberniex250371773
Fatal error: Call to undefined function curl_init() in C:\xampp\htdocs\Economicchef\WA_eCart\WA_eCart_UPS_PHP.php on line 69
What does this mean?
CraigRBeta Tester
if you haven't already got one, create a php test page by adding
<?php phpinfo(); ?>
in the body tag of a new page
scroll down to see if you have curl enabled.
if not, you need to edit your php.ini settings
In the php.inni file you need to make sure the curl extesnion is enabled.
Find the following line in the php.ini file:
;extension=php_curl.dll
and remove the leading semi colon:
then restart the php server.
Its a simple Issues
You Just find all the php.ini files in your server(xampp) where you installed.
and fine the line curl and remove the ( ; ) semicolon in front of this line after that save those files.
Note: After all the changes you must restart your server.
Also refer: how-to-enable-curl-in-php/
